Project Black Bat
257 replies to this topic
#41 Ormes
Ormes
  • 4,612 posts
Posted 09 June 2014 - 07:41 PM
Many thanks Nev thumbsup
#42 Ormes
Ormes
  • 4,612 posts
Posted 16 August 2014 - 05:34 PM
Quick update as I've not posted for a while... Car is now SORNed and still doesn't have an MOT :( ...I finally motivated myself to put it all back together and noticed that the flange on the cat was at a different angle to the flange on the decat pipe.  Laim @ MMG advised it would not line up without some serious messing around, so kindly arranged for 2Bular to take both the cat and decat sections back to make the cat the same as the decat.  Liam's been a great help as always... but the exhaust hasn't been collected yet, so it's going to be a while before she is back on the road.
Haven't actually worked on the car for a while but am building up a collection of parts to fit :)
-Rear tow eye
-Front tow eye (I'll only fit when I track)
-Shift-i shift light
-Gear knob
-Carbon gear stick cover
I have also just done a bit of a 3 way swap and sold my Courtenay tophat and am waiting for delivery of a DG tophat/plenum and hard pipe IC to tophat/plenum kit.
I have recently bought a splitter also but may have had a change of heart... think I may look at creating one from plywood, so any advice would be useful... especially on the fitting approach and how to get it to sit correctly given the front of the VX isn't completely flat bottomed.
thumbsup
Edited by Ormes, 16 August 2014 - 05:36 PM.
#43 Nev
Posted 16 August 2014 - 07:11 PM
In my experience/experimentation a splitter does very little until it is about 6 to 7 CM off the floor Alex, which makes it non road compliant :( Mind you, my front clam shape is a bit diff to yours, so maybe it isn't comparable. I am thinking of taking mine off to see if I even notice the difference, I suspect not, in which case I will leave it off.
Edited by Nev, 16 August 2014 - 07:13 PM.
#44 Ormes
Ormes
  • 4,612 posts
Posted 29 August 2014 - 06:07 PM
DG intake kit sanded, polished and ready to fit (why I spend hours doing this kind of sh1t I will never know :))
thumbsup
#45 Duncan VXR
Duncan VXR
  • 5,284 posts
Posted 29 August 2014 - 08:05 PM
Looks EPIC ;) DG
#46 Nev
Posted 29 August 2014 - 08:13 PM
Is that 2.25 inch I/D ?
Edited by Nev, 29 August 2014 - 08:13 PM.
#47 Ormes
Ormes
  • 4,612 posts
Posted 29 August 2014 - 08:25 PM
 thumbsup
#48 hairy
hairy
    Moonlander
  • 6,064 posts
Posted 31 August 2014 - 08:10 PM
Shiney!
#49 JG
JG
  • 13,617 posts
Posted 31 August 2014 - 08:45 PM
Thumbsuo
#50 Ormes
Ormes
  • 4,612 posts
Posted 21 September 2014 - 05:30 PM
Did some work on the VX for the first time in ages today...
Fitted new gasket on the throttle body... with hindsight, the original looked fine but hey:
Fitted the DG intake kit... was harder to fit that I expected.  I had to delete the alternator shield as it fouled:
There was a bit of trial and error involved in figuring out the order in which to assemble and attach the kit... for future reference, I found the easiest method was to assemble the whole kit and insert from above with a number of test fits and tweaks to the alignment before finally tightening the jubilees on the kit, sliding down one last time and then attaching the top hat/plenum and then the jubilees at the IC end:
I must have removed and refitted the arch liners a dozen times, but could I get it to go back in?... in the end I had to walk away before I put my fist through something... I will save that argument for another day... can't see that the positioning of the hard pipe is any different to the Courtenay one I had in there before, but I could be wrong.
Also... I have finally got the exhaust sections back from 2Bular, so just need to fit the arch liner, cat, lambda and undertrays, MOT her and then maybe I may drive her before the year is out  rallly
thumbsup
#51 Nev
Posted 22 September 2014 - 11:42 AM
Good to see progress :)
#52 Rickwoo118
Rickwoo118
  • 5,800 posts
Posted 22 September 2014 - 06:10 PM
Looking good......what's next on your agenda?
#53 Ormes
Ormes
  • 4,612 posts
Posted 22 September 2014 - 08:07 PM
Cheers guys thumbsup
Just a few small jobs here and there... nothing major at the moment :)
#54 Nev
Posted 22 September 2014 - 08:27 PM
Next on agenda: MOT + TAX, followed by a long weekend blatting round the Brecon beacons non stop until you've spent £200 on petrol !
Edited by Nev, 22 September 2014 - 08:28 PM.
#55 Ormes
Ormes
  • 4,612 posts
Posted 22 September 2014 - 08:41 PM
Just what the doctor ordered :)
thumbsup
#56 Ormes
Ormes
  • 4,612 posts
Posted 09 November 2014 - 06:43 PM
Spent hours trying to get the arch liner and the DG intake kit to live happily together but they just don't.  With the pipework pushed to it's limits of alignment, I can just about force the liner in, but it still rests heavily against the pipework, which I am not comfortable with.  Unfortunately, after wasting LOTS of time and money, I need to write it off as a bad idea and buy another kit... probably a Courtenay one again!
Oh well, you live, learn and move forward.
#57 fezzasus
Posted 09 November 2014 - 08:07 PM
just a thought, is that because the charge cooler setups raise the outlet compared to the intercooler?
#58 Ormes
Ormes
  • 4,612 posts
Posted 09 November 2014 - 08:48 PM
Hi Fezzasus, cheers for sharing your thoughts... always appreciated thumbsup
I am on a standard IC setup... however if I was using a CC setup and the outlet is indeed higher, I very much doubt that it would be a problem as it is the inside edge of the liner that fouls, in the area just above and to the right of the damper mount.
Cheers
Alex
thumbsup
#59 Ormes
Ormes
  • 4,612 posts
Posted 10 November 2014 - 07:42 PM
Think I may have just thought of a way to resolve this...
I have a pipe like this...
The kink in the straight may provide sufficient space for the liner to clear.  I am going to consider creating a frankenstein, chopping the Courtenay pipe just after the kink, and chopping the long hard pipe in half.  It may sound nuts but I think it will do the trick :)
#60 Nev
Posted 10 November 2014 - 07:44 PM
Don't forget to take into account that the engine will rock forward by approx. 1 to 2 inches when you boot it.
