MOT Passed... No advisories. Just taxed...
Me - "Has it passed"
MOT man - "It has a page full of advisories"
Me - "OH"
MOT man - "only joking... I can usually always find something... but it's passed with no advisories"
Me - "Wooohoooo"
Posted 14 May 2015 - 03:03 PM
Me - "OH"
Me - "Wooohoooo"
Posted 14 May 2015 - 06:41 PM
Posted 14 May 2015 - 07:19 PM
Shame it's raining tonight, or won't that stop you ?!
Edited by Nev, 14 May 2015 - 07:19 PM.
Posted 14 May 2015 - 08:21 PM
Posted 15 May 2015 - 05:21 AM
Too much rain!!! Hoping for dry roads after work today... or tomorrow morning.
Posted 15 May 2015 - 07:16 AM
It's not raining here!
...yet !
Good luck with the Hoon.
Edited by Nev, 15 May 2015 - 07:16 AM.
Posted 15 May 2015 - 07:25 AM
...yet ! Good luck with the Hoon.It's not raining here!
Posted 22 May 2015 - 05:54 AM
Drove the VX for the first time in the dry since my MOT yesterday evening and again this morning... It is great to be back... I'd forgotten how quick a stage 2 turbo is
Posted 22 May 2015 - 08:03 PM
C'mon then Alex, set up the next meet!
Posted 23 May 2015 - 07:30 AM
Fitted new gear knob (thanks Mollie6) and the Passanger footrest I've had in the garage for a few years, then gave the interior a clean:
Fitted new rear tow hook:
Gave the exterior a clean:
Posted 23 May 2015 - 08:34 AM
Posted 22 June 2015 - 05:31 PM
Small update:
Fitted a CG Lock and had a test drive... the fit is a little "amateurish" but it does do the job... so far I like it.
Over the weekend I happened to notice that the o/s/r inboard toe link ball joint was weaping some lube... inspected and found a 5mm cut in the boot. Despite the toe link assembly x 2 being less than 18 months old, I have bought new inner ball joints (genuine Lotus), and will replace them pretty soon.
Ripped the dash plates off in readiness for fitting my Shift-I shift light. In the process of cleaning up the double sided foam tape... definately going to use velcro when refitting!
Also, ordered the bits for a gearbox breather and will fit soon... I have just bought a sheet metal bender/folder so hoping I can make some elaborate and pointless bracket to hang it off
One last thing... the tow hook needs to be spaced by washers to get it to play nicely with the diffuser, so I got one spacer (washer) laser cut by a company I found online... awaiting delivery before the verdict
Posted 22 June 2015 - 06:39 PM
Posted 22 June 2015 - 06:50 PM
Shiney shiney, now come for a drive with Nipper and I and I will show you where all the dirt in the west country is !
...only if your missus cleans it afterwards
Just noticed that the bloody cam to crank breather is weaping again and the jubilees have cut into the silicone... new one on order.
Posted 22 June 2015 - 06:56 PM
IMO silicone ones can't cope with the heat and you'll probably end up replacing an off the shelf item soon again. I'd recommend buying a proper reinforced oil resistant pipe from a reputable manufacturer. I bought some Goodridge stuff for my turbo oil return pipe (which must get well hot) and it is still going strong after 25k miles....only if your missus cleans it afterwardsShiney shiney, now come for a drive with Nipper and I and I will show you where all the dirt in the west country is !
Edited by Nev, 22 June 2015 - 06:59 PM.
Posted 26 July 2015 - 01:43 PM
UPDATE:
Made and fitted a gearbox breather kit.
Bought some parts, a sheet metal bender and bench grinder:
After making cardboard templates etc., I cut some stainless steel:
Bent, polished and drilled (bit on the right is a test bit):
The finished kit... including an optional ingress cover:
(More to follow)
Posted 26 July 2015 - 01:44 PM
Fitted... left off the ingress cover for now as I rarely use it in the wet:
Posted 26 July 2015 - 02:06 PM
Posted 26 July 2015 - 02:25 PM
Tidy
Posted 26 July 2015 - 07:06 PM
