Can anyone tell me what i need to fit my AEM oil pressure gauge? Im guessing i will need some kind of adapter? Maybe such as this? http://www.speedflow...vc50-1384-p.asp But any pointers to what i need is appreciated
Posted 19 May 2013 - 09:49 PM
Posted 19 May 2013 - 09:58 PM
Sensor clearance can be tight with a sandwich plate fitted. This is about as well as you can orientate things and on full suspension travel things may get hit. You would be better off taking the feeds from somewhere else.
Posted 19 May 2013 - 10:00 PM
Edited by slindborg, 19 May 2013 - 10:00 PM.
Edited by Bumblebee, 19 May 2013 - 10:06 PM.
Posted 19 May 2013 - 10:01 PM
Or getting a sensor that isn't fcuking massive
True but it was not just the bell shaped housing that was the issue. (or non issue in my case)
Posted 19 May 2013 - 10:45 PM
did you see the one I fitted to mine aimy?
it was similar to dab of oppos, but a bit smaller.
no issues with wishbone clearance, only cost about £25 off ebay.
come round and ill show you how it goes together
Posted 20 May 2013 - 07:22 AM
The Z20LET engine block has an oil gallery take-off point already in it. For OEM setup it has a M14x1.5 blanking bolt inserted into it. You could make a reaplcement M14x15 bolt with a 1/4 NPT thread drilled into the centre of it and install that in the block instead of the OEM blanking bolt. Then directly screw your oil pressure sensor with it's 1/4" NPT into it. The bolt hole is close to and slightly above the oil pressure sensor (ie below and right of the intake manifold). This eliminates the need for an extra sandwich plate.
Edited by Nev, 20 May 2013 - 07:24 AM.
Posted 20 May 2013 - 07:50 AM
Yep, stuff from Autometer is like Scotch Mist.
Many more options at a fraction of the price on flidBay
Posted 20 May 2013 - 08:22 AM
Posted 20 May 2013 - 08:30 AM
Posted 20 May 2013 - 08:38 AM
Just google M14 1 8 npt adaptor
Posted 20 May 2013 - 08:46 AM
That's what all of the ebay items are.
Posted 20 May 2013 - 08:49 AM
Sorry, Nev had mentioned 1/4 NPT.
Posted 20 May 2013 - 09:08 AM
Posted 20 May 2013 - 10:16 AM
Ooops, I meant 1/8" NPT (not 1/4" inch) !
Posted 20 May 2013 - 11:25 AM
The green arrow in this pic points are the blanking bolt.
Posted 20 May 2013 - 06:13 PM
i have an account with a supply that does adaptors if you need one m14 x1.5 to 1/8 bsp is the norm i think
its about £5 plus delivery
Posted 20 February 2020 - 07:21 PM
Is this the correct oil gallery that's been blanked?
