Harrop Acceleration Vid
#21
Posted 21 May 2013 - 01:27 PM
#22
Posted 21 May 2013 - 02:35 PM
#23
Posted 21 May 2013 - 04:42 PM
Here is the dyno-printout and the boost vs rpm logging:
You can see that the boost is too less and the torque around 3000 is too less, too.
That are both problems i talked about.
And you can see in the graph that i need to built my engine stable enough to rev more than 7000 ;-)
Edited by ultimate, 21 May 2013 - 04:43 PM.
#24
Posted 21 May 2013 - 04:59 PM
#25
Posted 21 May 2013 - 05:06 PM
did you get full boost on the dyno?
#26
Posted 21 May 2013 - 05:17 PM
Anyone know how many Harrops are running Peters software in Europe on a 2.2 engine?
Nor certain why the knock problem I have asked Jon about it.
when we put the 2.9 pulley on first run was 366bhp, it dropped a bit after 3 runs in a few mins down to 355bhp ish.
I am hoping that with water injection and back to the 2.8 pulley I should be able to achieve as sensible constant power level.
Edited by NickB777, 21 May 2013 - 05:18 PM.
#27
Posted 21 May 2013 - 05:19 PM
#28
Posted 21 May 2013 - 05:22 PM
was thinking on a 2.2 z22se engine. wondering if the 2.0lt engine is causing some of your issues?
is he having any problems?
#29
Posted 21 May 2013 - 05:29 PM
#30
Posted 21 May 2013 - 05:40 PM
I made it 60 - 100 in 5 seconds? Assuming a decent launch and a sub 4 second to 60, that's sub 10 seconds to 100mph! Nice
#31
Posted 21 May 2013 - 05:45 PM
yep sub 4 to 60 mph or very near would need, only problem would be the clutch if you do that sort of launch too often
Edited by NickB777, 21 May 2013 - 05:46 PM.
#32
My old charger made 9.9 seconds to 100I made it 60 - 100 in 5 seconds? Assuming a decent launch and a sub 4 second to 60, that's sub 10 seconds to 100mph! Nice
#33
Posted 21 May 2013 - 05:48 PM
#34
Posted 21 May 2013 - 06:58 PM
Thats v good. What kind of bhp were you running?
#35
Posted 21 May 2013 - 07:32 PM
Awesome Chris
#36
Posted 21 May 2013 - 07:46 PM
What seems to be interesting is that the size of the pulley doesnt directly effect the boost level. Take these examples for example.. Nick - 377 bhp 2.8" pulley Nickb777 - 360bhp 2.9" pulley Mike - 350bhp 2.75" pulley All 3 cars were running pretty much the same boost pressure and interestingly nick (377) had less power / torque up the rev range and only in the last 1000rpm did it catch up and overtake the other 2 cars. Also after god knows how many runs the 377bhp dropped to 360bhp.
It has more to do with Mike's 4-2-1 manifold and Nick's 4-1 manifold than pulley size.
Same reason why mine has more mid range than all the other ITB cars
#37
Posted 21 May 2013 - 07:54 PM
No, Smiley is making a surreptitious reference to the OBDTuner reflash, which he believes fixes everything known to mankind, except his exhaust noise.
That hurts
#38
Posted 21 May 2013 - 08:27 PM
I promise you, ZT1 wont make any difference either. I think that's the version in my silencer and 80% of it hasn't even melted and expanded fully. I'm inclined to wrap the perforated tube with one or two layers of ZT1 (as it certainly doesn't break down and blow out of the exhaust) and then go back to a normal stuffing for the rest of the space in the silencer which might have slighty better acoustic properties.That hurtsNo, Smiley is making a surreptitious reference to the OBDTuner reflash, which he believes fixes everything known to mankind, except his exhaust noise.
#39
Posted 21 May 2013 - 08:30 PM
that was 296bhp and 254ftlb
#40
Posted 22 May 2013 - 03:54 PM
A good option might be acustafil around the pipe acting like you would with wire wool then pack the rest with the silentex I have in my tullet. It comes in plastic bags and looks like cotton wool this makes packing very easy. I have not lost any Silentex out of mine but it is not SC.I promise you, ZT1 wont make any difference either. I think that's the version in my silencer and 80% of it hasn't even melted and expanded fully. I'm inclined to wrap the perforated tube with one or two layers of ZT1 (as it certainly doesn't break down and blow out of the exhaust) and then go back to a normal stuffing for the rest of the space in the silencer which might have slighty better acoustic properties.That hurtsNo, Smiley is making a surreptitious reference to the OBDTuner reflash, which he believes fixes everything known to mankind, except his exhaust noise.
