Things I need to order.
6 point harness
Cage
Spreader plates for harness
Helmet
Hans
Suit
Gloves
Fire proof socks, bottoms, top, balaclava
Fire extinguisher system
Electrical cutoff
Rainlight
Posted 08 June 2016 - 08:30 PM
6 point harness
Cage
Helmet
Hans
Suit
Gloves
Electrical cutoff
Rainlight
Posted 08 June 2016 - 08:40 PM
Todays fast lap video
I have more from both days but need to cook myself some tea first.
Posted 09 June 2016 - 06:07 AM
Do you happen to know how much your car weighs these days ?
Edited by Nev, 09 June 2016 - 06:08 AM.
Posted 09 June 2016 - 06:40 AM
Still in the region of 850, nothings really changed.
Posted 09 June 2016 - 08:45 AM
Bit scruffy on the last corner but other than that looking properly quick. It looks like you are getting close to the limit of those tyres, what are they?
Posted 09 June 2016 - 09:16 AM
I think I provoked that on purpose, bit of a show for those watching.
They are 888's although they have done 8-10 trackdays.
Posted 09 June 2016 - 09:35 AM
Will easily have cost you 2 tenths
Posted 10 June 2016 - 08:41 AM
I'd does seem to slow me down a chunk.
A few other highlights of the day. A couple of sideways moments, following a poorly driven 380bhp race seat leon, a clio with a sequential box, a porsche carrera, a caterham with a GSXR 1000 engine (fastest thing that day) and a little spin at the end.
Posted 10 June 2016 - 10:28 AM
Like the way the Leon puts two wheels well over the line on entry to setup the corner and then proceeds to miss the apex by a good margin.
By the looks of that cage I'd say it's an MK indy rather than a Cat.
Posted 10 June 2016 - 10:41 AM
I meant to put caterfield as I have no idea what it was. Immaculate with lots of carbon though. It was only the guys second ever trackday. Quite a car to jump straight into!
I have no idea what the seat driver was doing. Apparently he was getting ready for a 24 hour race of some sort.
Posted 10 June 2016 - 12:44 PM
Posted 15 June 2016 - 06:12 PM
Posted 17 June 2016 - 06:50 PM
Posted 17 June 2016 - 07:11 PM
I went for the sport 2. I don't know why as it was the same price, I've not looked at yours to see the difference.
They only sent one set of lens cleaner and helmet wax so I've spoken to them and they are sending a second set when they send the helmets.
Posted 17 June 2016 - 07:33 PM
Edited by SteveA, 17 June 2016 - 07:34 PM.
Posted 17 June 2016 - 07:51 PM
Haha good point. I'll use it on my bike helmet!
Posted 02 August 2016 - 08:10 PM
Fitted new HCBs today, one thing to note is if you have the elise parts bump steer arms you need shorter front bolts 45/50mm instead of 60mm.
Also fitted 10.9 toe links so they are torqued up tighter now.
Got the 2 rear ZZRs put on the rear, will do the fronts tomorrow.
Ordered the 2-11 crotch 6 point bracket and spreader plate. Need to order some longer eye bolts though tonight.
Posted 06 August 2016 - 09:33 PM
Started fitting the cage today, holy fcuking sh*t balls batman.
Collected it from Safety Devices yesterday. Their instructions are a bit sh*t but the first part is to check the fitting kit. But nowhere tells you what is supposed to be in it. Turns out I'm missing some bolts, brilliant. But I may have some or will buy Monday if I dont.
Will update with pictures and stuff in a min.
Posted 06 August 2016 - 10:28 PM
The bits of the fitting kit minus the bolts for bolting down the front of the cage.
Made space in the main garage for the vx to be worked on.
Exactly 2 hours to get the seats out and rear clam off.
Seperation the roll bar from the bulk head was a fcuked. Don't ever just use a Stanley, get a wire saw.
Where the old bar sat, the pop rivets get drilled and then the plate underneath place 65mm further back ish
Using a gate hinge and some tape to stop the plate falling in the fuel tank area.
The hole that needed enlarging for the bars that go to the subframe
What I thought would be a big enough hole. It wasn't.
How much wider the cage was to the cills.
Got it through the gap with a ratchet strap and some creaking and cracking of the fibreglass. That's how I left it and am now in the pub. Not a great idea.
