Im Back Back
440 replies to this topic
#61 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 16 June 2013 - 11:14 AM
#62 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 16 June 2013 - 01:06 PM
might as well do the clutch  thumbsup
#63 Zoobeef
Zoobeef
  • 11,103 posts
Posted 20 June 2013 - 09:33 PM
Yeah would do. Do you SC boys use an upgraded one or does the standard one handle it? Been talking to JK comp and their new vx seats are alot stronger as they have an extra skin and also sit lower as they sit between the rails. Also provide an extra 2 pieces of padding in the sides to hold us skinny blokes more snugly! Now, shall i buy Steve A's RC6 brake pads? Hmmmmmmm.
#64 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 20 June 2013 - 09:41 PM
Any pics of the new seats yet dude?
#65 Bargi
Bargi
  • 4,483 posts
Posted 20 June 2013 - 09:42 PM
Standard clutch is fine, get the 6s you won't regret it!
#66 Zoobeef
Zoobeef
  • 11,103 posts
Posted 20 June 2013 - 09:47 PM
Not yet, apparently he's already send a set to a vx owner and is waiting for some feedback. Normal wait is 3-4 weeks so im going to push to have them for the national!
#67 Zoobeef
Zoobeef
  • 11,103 posts
Posted 20 June 2013 - 09:48 PM
Think I will. The rears on the car are almost gone so need new ones anyway
#68 Zoobeef
Zoobeef
  • 11,103 posts
Posted 25 June 2013 - 12:58 PM
Just ordered jk composite seats. New design as they are still developing brackets. Mine will use extra brackets that fit to the original runners but they are hoping the final finished ones will have the brackets built in and plug and play. They have an extra skin so are a lot stronger and sit lower in the runners. Should take 2-3 weeks to make.
#69 Nev
Posted 25 June 2013 - 02:17 PM
RC6 pads do grip well once they are warmed up.
Nice purchase Mark, I've been vaguely considering doing the same, though will likely wait for prices to drop further.
#70 dw1
dw1
  • 3,043 posts
Posted 27 June 2013 - 07:32 AM
Zoobeef, on 25 May 2013 - 8:55 PM, said:
turbobob, on 25 May 2013 - 8:53 PM, said:
Its not been that long has it? :o
Yeah 10/12/2010 :( Had the noble 19 months :0
I'm a bit slow and only just seen you're back. Welcome back!!! Also can't believe you've had the noble that long, seems like only yesterday that I was reading your Afgan posts and just getting the noble.
#71 Rickwoo118
Rickwoo118
  • 5,800 posts
Posted 28 June 2013 - 06:13 AM
Zoobeef, on 16 Jun 2013 - 11:13 AM, said:
So, what have I been doing? Stripped the interior completely, cut off the headrests and fitted Steve A's harness bar and harnesses. On removing the egr valve one bolt sheered. On extracting that it took the end of the casting off so had to drill and new hole. All fitted and cheated now though. The front clam came off yesterday and the coolant was just water so drained all that. Removed the fezzasaurus heater (which is for sale) and bypassed that. Removed the fog lights but left the brackets in as the look like they suppose the clam a fair bit. Can I remove as well do you think? So today I need to refill the coolant, change the oil and bleed the brakes. Need to choose some seats to buy, find a zafira gearbox. And while I'm doing that I may as well do the flywheel. Then may as well push it as far as balencer delete and new chain. Then find a tubby back box and upgrade the rest of the system to 2.5. I don't want to SC yet as id like to track it as an NA first but I don't want to do anything to it which I have to change again for SC.
God...sounds like you been busy....looking good so far.
#72 SteveA
SteveA
  • 9,155 posts
Posted 03 July 2013 - 12:00 PM
Pro-alloy tank is waiting for you when you are ready :lol:
#73 Zoobeef
Zoobeef
  • 11,103 posts
Posted 13 July 2013 - 11:34 AM
Well one seats in and fitted. The other will be delivered this week as they are modifying the standard runner as the brackets on it don't bolt on and off like the drivers side.
#74 Bargi
Bargi
  • 4,483 posts
Posted 13 July 2013 - 01:48 PM
and they fit and sit OK without any mods?
#75 Zoobeef
Zoobeef
  • 11,103 posts
Posted 13 July 2013 - 01:53 PM
The made some brackets to bolt to the original subframes once you take off the original brackets. The new brackets have some adjustment so you can raise or lower the rear of the seat too.
#76 Bargi
Bargi
  • 4,483 posts
Posted 13 July 2013 - 02:11 PM
excellent, how much all up?
#77 Zoobeef
Zoobeef
  • 11,103 posts
Posted 13 July 2013 - 02:53 PM
The price they gave me originally was £329 a seat including brackets and 5 piece upholstery.
#78 Rusty789
Rusty789
    Ginger Ninja
  • 2,120 posts
Posted 13 July 2013 - 02:56 PM
And what did you actually pay? lol
#79 Zoobeef
Zoobeef
  • 11,103 posts
Posted 13 July 2013 - 03:45 PM
A lot less than that as they were still being developed :P
#80 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 13 July 2013 - 07:41 PM
Can you have the seat belts still or just the harnesses?
