Posted 28 May 2013 - 08:27 PM
Posted 28 May 2013 - 08:43 PM
Posted 28 May 2013 - 08:49 PM
Posted 28 May 2013 - 08:56 PM
Posted 28 May 2013 - 08:58 PM
Yep think so. Can't remember the make, yellow ones. The noise only occasionally happens, normally down my bumpy road but only happens for a few seconds. I am determined to find the cause though without spending loads of money.
Good luck, I have spent frigging ages trying to find a rattle on mine, checked every single thing a zillion times
Posted 28 May 2013 - 09:05 PM
Posted 28 May 2013 - 09:07 PM
Solved
Posted 28 May 2013 - 09:10 PM
Posted 28 May 2013 - 09:19 PM
Posted 28 May 2013 - 09:39 PM
Its a built i feature of the VX220 ownership.
I started doing this to mine.....door pins were the best upgrade..... but then after a while you hear more and more... then give up....
Posted 28 May 2013 - 10:58 PM
Posted 29 May 2013 - 08:11 AM
Can't hear my rattles.....just exhaust, turbo and chatter oh and lots of wind!Best cure: 1 - Remove roof. 2 - Drive fast. You will then: a - not be able to hear anything above the racket of open-top hoonery & b - be having so much fun you won't care about rattles.
Posted 29 May 2013 - 08:14 AM
Tadts
Although worth a check under the seats
Amazing what a 5p can do...
Posted 29 May 2013 - 12:15 PM
yep checked under seats already, found some money, some illegal smoking products, 4 lighters and a wageslip from a previous owner. But still have a damn rattle.
Posted 29 May 2013 - 10:05 PM
The illegal smoking stuff is mine just send it on. I can hear this one rattle above all the rest like you and cant find it.I am at the point I would pay to have it sorted and that's bad
Posted 30 May 2013 - 09:38 PM
Posted 31 May 2013 - 06:04 AM
Posted 31 May 2013 - 06:42 AM
Posted 22 June 2014 - 09:32 PM
I'm loving my n/a vx but have an annoying rattle that only occasionally happens on bumpy roads. Sounds like a small chain rattle or bolt with washer rattling. Not very loud but still annoying. So after taking off my under trays I thought I would let you all know what rattles I have fixed so far. This could help other people fix their rattles and in return maybe you could offer me some ideas on fixing mine. Heat shield around gaiter was bent, so bent that back. Interior back panel trim was loose next to door sills some padded tape applied and fixed that rattle. Rear brake pads were rattling, easy to check, let handbrake of and check for pad movement. Passenger side was very loose. Refitted a bit of antirattle pad and pad grease and rattle gone. Exhaust movement checked and all brackets. All suspension checked and cleaned/ lubricated. All obviously pipe work/ cables checked. Handbrake cables zip tied up. I have applied spray grease to bottom of suspension spring where they fit in the cups. Sadly I haven't fixed my rattle but the above may help others. Could it be my shocks making a noise on bumpy roads?
Hi Ant1
This sounds very similar to the rattle im getting from the back at the minute. Did you ever find out the cause of the annoying rattle as its driving me crackers.
Posted 24 June 2014 - 08:32 PM
Also tagged with one or more of these keywords: rattle, noise
General Discussion →
VX220 Discussion →
Supercharged Vx's / Noise / TrackdaysStarted by WazzaVX220 , 31 Mar 2018 ![]() |
VX220 Discussion →
Leaking Exhaust Manifold Noise?Started by Hekke , 18 Nov 2014 ![]() |
VX220 Discussion →
Help With My Window. Lincolnshire / North East.Started by Benzola , 11 Oct 2013 ![]() |
VX220 Discussion →
Strange Sound Occuring...Started by D3YMO , 22 May 2013 ![]() |
Tuning & Modifications →
Simple Free Airbox Mod – Definitive Guide – Download Here:Started by Benzola , 27 Feb 2013 ![]() |
