mild (low carbon) steel is more like 280MPa, structural steel is ~350 MPa, you have to go to a pretty high strength steel to get 400MPa
I've got a tool up North, infact if you asked last weekend I could have had it taken to Bolton for you.
I ran the calc back through using 280MPa and it came out around 20mm, so it sounds like we're about right.
It might also explain why the EP tool strips its threads so easily, being only 12mm.
Maybe I should have asked to borrow one, but I'm doing my front and rears separately so I'd have needed it for a month or two which is a bit cheeky IMO.
Edited by Gedi, 04 June 2013 - 05:45 PM.
