Hmm, has anyone on here fitted one of these with a Harrop yet? The one I have here doesn't fit. Either needs the Harrop spaced up or the sensor may need 'trimming'..... What's the preferred method then?
T Map Sensors
Posted 13 June 2013 - 01:28 PM
Posted 13 June 2013 - 01:31 PM
Lee has fitted a 2.5bar TMAP to his.
Posted 13 June 2013 - 01:33 PM
Is it just the plug that's fouling? There's a number of different compatible plugs, so maybe a skinnier one would work.
Posted 13 June 2013 - 01:37 PM
I've not even got the plug on yet. The sensor itself wont go on....
Bosch 0 281 002 437
http://www.ebay.co.u...2-/150963367912
Posted 13 June 2013 - 01:46 PM
I've got a 2.5bar (0 261 230 042) and a 3.0bar (0 281 002 437) sensor sat on the desk in front of me and they're both identical for overall size. The only thing that the 3.0bar has, that the 2.5bar doesn't, is that raised hole for the fixing bolt with the bush inside it. The 2.5bar is just a flat basic hole in the base of that section.
you can't use the bolt the harrop just sat on it and held it down I used the 2.5 bar unit and cut the fixing plate off the sensor get the dremel out
Edited by NickB777, 13 June 2013 - 01:50 PM.
Posted 13 June 2013 - 03:48 PM
You need to mod the sensor mounting and/or fit it without bolt so the Harrop presses it down.
Edited by Exmantaa, 13 June 2013 - 03:53 PM.
Posted 13 June 2013 - 04:31 PM
Ah so 'trimming' was the answer after all Thanks again gents
Posted 14 June 2013 - 06:48 AM
Bosch 0 281 002 437
Is this the map sensor i need for my harrop to stop it cutting out at 150 mph?
Posted 14 June 2013 - 07:23 AM
No, you need an aftermarket ECU or the Dutch reflash to remove the built-in speed limiter, by the sound of it.
Posted 14 June 2013 - 08:01 AM
Posted 14 June 2013 - 12:54 PM
I wonder if disconnecting the pss side rear hub would stop that issue?
Posted 14 June 2013 - 12:58 PM
Its only on private roads that i do them speeds It more to do with the car going into limp mode when hitting them speeds and ive been reading its to do with the map sensor as i know cliffie is having the same problems.
Posted 14 June 2013 - 01:05 PM
The MAP sensor limp mode isn't road speed related. It's boost related. Like going from a steady state cruise to instant WOT. That might happen at 50mph or 250mph. Your's sounds like the ECU's built-in speed limiter cutting in.
But yes, in any case, you should get a larger MAP sensor and the remap (or Dutch reflash) to support it.
Posted 14 June 2013 - 01:30 PM
Hmm, just found another plug connector that's identical to the Tmap sensor plug. Anyone know what this is..?
Posted 14 June 2013 - 01:31 PM
Lambda? And the spare lambda type plug on the NA loom with no use.
Posted 14 June 2013 - 01:50 PM
lol, I might chop the fcuker off and find a use for it
