New Front Splitter Design
Posted 17 June 2013 - 07:03 PM
Splitter is a bit shorter than old version and have raised front lip by about 10mm to help
With ground clearance on lower cars. Also sides are now a lower profile.
Have a look and tell me what you think
Posted 17 June 2013 - 07:07 PM
Posted 17 June 2013 - 07:15 PM
Posted 17 June 2013 - 07:17 PM
Posted 17 June 2013 - 07:41 PM
Posted 17 June 2013 - 07:46 PM
Nice.
Posted 17 June 2013 - 07:47 PM
Like it
Posted 17 June 2013 - 08:11 PM
Posted 17 June 2013 - 08:36 PM
side bits are very difficult as the clam sides go under so makes deciding what way looks best for a finnished product.
i still have a bit more to do to finnish it the side bits are fairly flat so could have little flat winglets added as this was my thoughts from outset.
i will be making splitter in two sections (left and right side) with a split in middle. reason for this is two things one is making postage easier
and secondly if you had a knock on one side only then you could replace just that side instead of a whole new splitter.
pictures arnt best as off phone so will put some more up as soon as ive finnished.
Posted 17 June 2013 - 08:38 PM
Posted 17 June 2013 - 08:40 PM
found picture, these are the wood based splitters?
Edited by robin, 17 June 2013 - 08:45 PM.
Posted 17 June 2013 - 08:44 PM
Posted 17 June 2013 - 08:46 PM
Liking that one mate. Will have to put a order in at some point.
Edited by haggi961, 17 June 2013 - 08:47 PM.
Posted 17 June 2013 - 08:52 PM
the problem running chris style on a daily drive is hitting speed bumps and low objects, its fine for track use only but being people have damaged mine and other
splitters from normal driving i wouldnt like to suply something longer that what i allready do. Also if its the wood based items are these fixed to the metal undertray section as you will pass any knocks to fixing points and do more damage than just ripping the fiberglass one off.
Posted 17 June 2013 - 09:14 PM
Posted 17 June 2013 - 09:22 PM
Chris' is an undertray that replaces the metal piece and the wooden part is only shallow and bolts onto the replacement under tray.
Yes this is a great design and gives the owner the flexibility to fit whatever size shape splitter they like. (Also proven in Time Attack is strong as old nails!
Posted 17 June 2013 - 09:23 PM
Posted 17 June 2013 - 09:30 PM
Edited by Bumblebee, 17 June 2013 - 09:42 PM.
Posted 17 June 2013 - 09:34 PM
