Aem Infinity Ecu/dutch Ecu ?
63 replies to this topic
#41 CHILL Gone DUTCH
Posted 20 June 2013 - 07:52 PM
I didn't even realise it was a option when I decided to go Dutch Thought it was a turbo thing, I thought I had two options courtenays route or Dutch
#42 Bargi
Bargi
  • 4,483 posts
Posted 20 June 2013 - 08:04 PM
Switchable multi maps
The one Dunc sells can switch between 2 maps on the fly. Dutchy isnt live.
2 mins it takes, And you can switch between any file you have saved or borrowed
But you don't need a laptop with the other ECU :) And so what if you don't ever change it, then point is you can! :P
#43 slindborg
Posted 20 June 2013 - 08:28 PM
:lol: I'd be more hung up about other software features like a decent idle controller, part throttle smooooothness and so on. Seemingly the Dutch route is better than most.
#44 CHILL Gone DUTCH
Posted 20 June 2013 - 08:36 PM
I agree but am byest
#45 JohnTurbo
JohnTurbo
    SuperScruff
  • 3,635 posts
  • Interests:Performance cars!
Posted 20 June 2013 - 08:40 PM
byest = orkshen? (tee hee hee - this abuse from a dyslexic).
#46 CHILL Gone DUTCH
Posted 20 June 2013 - 08:41 PM
The spell check on the iPhone never bought it up
#47 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 21 June 2013 - 07:39 AM
Is it reeeaaallllly that important to have switchable maps, given you won't ever fcuking use them
It is for me. I would love the ability to have the chioce of pulleys to suit the circuits I go to and therefore would adore switchable maps. It would have saved us the balls up that was Snetterton this month.
#48 CHILL Gone DUTCH
Posted 21 June 2013 - 07:42 AM
Have you bit the bullet then
Edited by Chill, 21 June 2013 - 07:42 AM.
#49 Exmantaa
Posted 21 June 2013 - 08:00 AM
It will take you far longer to mount-up a different size pulley then to load a new map into your ecu through the OBD port...   ;-)
(LSJ ecu = 43 seconds and I assume OBD will be not much different.)
#50 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 21 June 2013 - 08:04 AM
Nope, don't have £70 let alone £700 to try it out. I need to get to the end of the season first.
#51 slindborg
Posted 21 June 2013 - 10:09 AM
Switchable is a stupid term in reality (bit like stage tuning :lol: )
yes have different calibration files to suit differing engine setups... but for most ECU's that would be enough stuff being different to warrant a new file to be flashed on rather than using a switch to jump to one different map.
And when you factor in the setup time for changing a pulley and re running on the dyno/track to set it up, thats not gonna be cheap :lol:
Edited by slindborg, 21 June 2013 - 10:10 AM.
#52 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 21 June 2013 - 10:47 AM
One option I would like to look at is a MOT friendly map, anyone know how this could be achieved?
#53 Bargi
Bargi
  • 4,483 posts
Posted 21 June 2013 - 11:09 AM
This I'm interested in, could you run decat all the time and have a map calibrated for MOT time?
#54 techieboy
Posted 21 June 2013 - 11:15 AM
Probably not. Think you'd still need a helpful MOT place but you'd be able to tune it get more sensible emissions (though you'd probably want a laptop with you to reload a different map for the way home), certainly better than my stage 3 and decat which I think just burns 50% of the fuel and fires the rest out of the back of the car.
Would probably be able to squeeze through on a 100-cell cat okay though.
#55 CHILL Gone DUTCH
Posted 21 June 2013 - 11:17 AM
I'm guessing you could put a lean map on it to get through MOT But I wouldent risk it, Maybe Peter could give you a rev limited map for MOT
#56 TheRealVXed
TheRealVXed
    Sidekick
  • 5,975 posts
Posted 21 June 2013 - 11:23 AM
With the dutch ECU you can map yourself right?
Buy a gas analyser and fiddle with the map in your garage until it passes... :)
#57 2deano5
2deano5
  • 668 posts
  • Interests:Cars / Squash
Or find a friendly MOT man an fiddle with his  :poke:
#58 CHILL Gone DUTCH
Posted 21 June 2013 - 11:25 AM
Could also mess with ignition setting as well as maps For different track conditions
#59 slindborg
Posted 21 June 2013 - 12:04 PM
Tbh, you SHOULD be able to have a balls out powwwaaahhhhhhh calibration which also has mot friendly idle and no load 3krpm emissions, obviously with a cat in place as there is shag all way you can pass a cat test without one (or a bent tester). If that's not the case then the chooner is a douchebag IMHO of course.
Edited by slindborg, 21 June 2013 - 12:04 PM.
#60 Exmantaa
Posted 21 June 2013 - 12:08 PM
Why do you need such a map?
It's mostly running in closed loop during MOT testing, so the O2 sensor should keep a 14.7 AFR. No problem, as long as you have a cat fiitted...
With decat pipe you could maybe try a full open loop setting with a lean map, but can imagine this will need some fiddling to pass.   :-/
