Ah, you made one already!!
Can be made a bit more tidy and made stronger with some welded side plates, but this does the job.
(not sure on clearances there, but can you not rotate the hose to the subframe side for better wheel clearance? And as the shock is on an angle, maybe the new bottom hole has to be slightly more out than the top one. But that's just minor tweaking.)
And hate to stir in this pot again, but longer dampers is probably only half of the solution, as this new found droop travel can only be used with sufficient spring load. (I do assume people want to keep their current ride height...)
So the spring perch will have to be set higher and without quite soft springs or helpers, the spring can become loose at full droop.
For me no problem, but it has to be considered of when you decide to lengthen your shocks...
Edited by Exmantaa, 26 July 2013 - 05:25 PM.
