Nothing to add here and my longer dampers indeed fouled the subframe with their 2.25 helper springs...
Only wished that Nitron or others had looked into this properly some years ago when they designed this...
your not alone...
What I find most annoying about all this is that it's been well known about for years, yet people chose to ignore it
If your having issues with helpers, two suggestions:
1) put the helpers on the eye end of the damper (they are fatter than the main springs as they are flat section)
2) if this does not help enough, use shorter main springs (being mindful of their more limited travel), typically you can get away with 6" springs at reasonable rates if you have helpers...
Edited by Scuffers, 29 July 2013 - 03:13 PM.
