DingKey Board Warrior LOLI've met him.Thing is he is informative and very tolerable when you meet him.He's as informative as he is intolerable.
#521
Posted 02 August 2013 - 01:19 PM
#522
Posted 27 April 2016 - 07:07 PM
Good God, I have finally read this painful saga, as my Nitrons have allowed more dings to appear on my rear upper wishbones.
However, in all of this there doesn't seem to be any info on how to get and fit the longer eylets for the short length Nitrons - can anyone help?
Also, can someone explain why installing thicker foam bump stops isn't a good solution, as that looks to be practical and easy to do?
Edited by Nev, 27 April 2016 - 07:07 PM.
#523
Posted 03 August 2016 - 02:59 AM
#524
Posted 03 August 2016 - 07:35 AM
Did you get this sorted Nev?Good God, I have finally read this painful saga, as my Nitrons have allowed more dings to appear on my rear upper wishbones. However, in all of this there doesn't seem to be any info on how to get and fit the longer eylets for the short length Nitrons - can anyone help? Also, can someone explain why installing thicker foam bump stops isn't a good solution, as that looks to be practical and easy to do?
#525
Posted 03 August 2016 - 12:18 PM
Sooo...are the 46's worth the extra money when it comes to performane on track? Skickat från min SM-G800F via Tapatalk
No as most people who have bought the 46"s have changed to diffrent shocks .i would say the 40'S are better than 46's
The way i see it is Nitron developed the 46's to make a better shock but the difference in performane just isn't there if its not broke don't fix it .
Edited by leevx2.2, 03 August 2016 - 12:21 PM.
#526
Posted 03 August 2016 - 02:03 PM
ntr-40 front
ntr-46 rear , hoffman valving
I still kept my ntr-40 rears , so I could try a back to back test, probably not notice much difference.
for me road manners are equally as important as track ultimate grip, at the moment the track balance is exceptional.
#527
Posted 03 August 2016 - 02:34 PM
...The question was which was better for track.
Lee's right. 46's are no better than 40's. So, It's not worth upgrading. In fact, If I was given a choice from the Nitron range at the moment, I'd go with 40's on my VX.
However, I still believe the Quantums have far a far better judged valving setup which allows for superior tyre contact with the tarmac compared to either of the Nitron options.
#528
Posted 03 August 2016 - 03:36 PM
#529
Posted 05 August 2016 - 08:54 AM
Interesting on reading the above. I bouight the latest NTR 40's with Hoffmans valving last year. I specced a slighlty too soft front spring at 400 with 550 at the rear and on my old 111r the roll into corners on track felt a little unbalanced front to rear.
I will definitely try quantum's when I go to an Exige V6 next year
#530
Posted 06 August 2016 - 07:55 PM
I went from NTR40 (hoffmans) to 46Race (Trackday Pro spec) with much harder springs and found the damping on road to be less crashy. I bought them before the naming reshuffle at Nitron so not sure how different they are to the newer NTR40 and 46.
#531
Posted 13 February 2019 - 11:22 PM
Hi,
I also bought a set of Nitron NTR shocks (40mm) , Fast Road specs, for my Elise - I think exactly same damper mounts as VX220. And I had some issues when trying to analyze/understand how it works, therefore I found your very interesting and comprehensive post.
So eventually I got similar conclusions :
- rear dampers seem ok (open length 428mm with ~82mm stroke until bump contact, compared to OEM Bilstein measured at 417 / 58 => increased stroke for Nitrons, with quite 50/50 bump/droop strokes when I measure the lenght at static height)
- but front dampers show same issue as you :
open length 328mm (Bilstein : 354mm)
stroke 43mm (Bilstein 54mm)
=> length when compressed to bump contat 285mm (Bilstein 300mm)
length 311mm at static ride height (120/125mm , lowered by 10mm from original ride height)
So I'm concerned with following topics :
- Nitron claims that FastRoad shock can run "at original ride height or slightly lower" - but it seems impossible, except if it can accept no droop at all
- even with -10mm lowering (I had to lower the car at 120/125mm with full tank and 80kg load), 311mm length means that droop is 40% only of full stroke. Seems quite low, as Bilstein OEM was ~65% droop (more droop than bump)
And I feel that droop is not enough, as I've been testing my new shocks on my favourite bumpy road : in some cases, front wheels lose contact of the ground (I have to say that it's in hardcore portions with reasonably high speeds, but well ...)
- additionnaly, overall stroke of the damper is offset compared to Bilstein : I lost 26mm stroke for droop (open length 326 vs. 354), and more 15mm on bump direction (285 vs. 300) => the wheel will probably touch the wheel arch in hard compressions
What do you think ?
Are my FastRoad shocks compliant with Nitron specs, or did they send me a wrong spec (Track day or Race versions that are too short ?) ?
If it's "normal" spec for FastRoad, what should be the appropriate setting for having acceptable droop/bump balance ?
Hope my english is not too bad for describing my conclusions.
Thanks for any answer and confirmation or help to get further specs understanding,
Just a note because we've discussed the rears at length - I hope everyone is aware the front situation is very much the same, with the exception of the potential to damage wishbones.
I'm hoping the results of this will be very positive!
Just to check I did some measurements on the front yesterday. Disclaimer: my car, my Nitrons (40's older ones).
- dampers full open: 325 mm
- dampers close till bumpstop: 285 mm
Not too bad, certainly not compared to the back. Could perhaps use a little more droop. If you increase the length with say 10 mm, you have about 15 mm more droop at the wheel and 15 mm less bump. But the bumpstop figures in large here. In case the available damper travel is 60 mm (bumpstop compressed to 10 mm instead of the 15 mm above), you have about 90 at the wheel and could get to 35 bump, 55 droop
Would be nice if someone else measures too and compare results.
#532
Posted 14 February 2019 - 11:12 AM
stroke 43mm
Hi,
What do you think ?
Your fronts seem to be close to "normal" Nitron spec, as my fronts measured 325-326mm open length with ~48mm travel without the stop. (add 10mm bump stop compression.)
You:
open length = 328mm
compressed to bump contact = 285mm (stroke 43mm, with bump stop ~53mm?)
Your static ride height = 311mm (17mm droop & 26mm bump travel. Incl stop ~36mm bump.)
So to get near 50:50 at your static ride height you can lower the front mounting bracket position. A 5mm change would give you around 22 / 21mm (simplified, as the shock is at an angle...) And if you add the extra bump stop compliance travel, an 8mm lowered bracket will give you 25mm droop/ 18mm bump + ~10mm stop travel.
(with 8mm you can just drill an extra hole for the M8 bolt in your bracket, but do use a big washer on the bolt!)
And take note that the added extra droop can cause stiff springs to become loose at full travel...
PS; front wheel ratio is around 1.45, so this 8mm added shock droop will give you ~12mm extra wheel droop.
#533
Posted 15 February 2019 - 08:07 PM
So, if my shocks are « normal » spec for FastRoad , it means that somehow Nitron lies when they promise « the ability to run at original ride heights (and slightly lowered if required) « ... if so, I find it quite disappointing from such a famous company in LiR world.
And I understand that ideal set up is 50:50 droop/bump balance at static ride height ? As Bilstein original setting is 65% droop, I was wondering if Nitrons would have different target set-up (but so far, Nitron never answered to my question).
About lowering the brackets : I’m not so pleased with drilling extra holes with maybe weakening the steel eventually. And I will have an issue on right side, with ABS unit that will not fit anymore with the bracket ?
#534
Posted 02 March 2020 - 01:47 PM
Also tagged with one or more of these keywords: nitron, ntr40, ntr46
The Market Place →
Group Buy Room →
Nitron Damper Group BuyStarted by Matthew Bentley Racing Ltd , 24 Apr 2018 ![]() |
General Discussion →
VX220 Discussion →
Nitron Ntr Advice. Na / Turbo Swap - Suspension.Started by dstarz7 , 26 Feb 2018 ![]() |
The Market Place →
Group Buy Room →
Nitron Street Series Group Buy - Until 20Th Nov 2016Started by Matthew Bentley Racing Ltd , 07 Nov 2016 ![]() |
VX220 Discussion →
Are Cup R Dampers Nitrons?Started by thejoaoserra , 30 Mar 2016 ![]() |
VX220 Discussion →
Damper Bearing O RingStarted by D-DAWG83 , 08 Feb 2016 ![]() |
