Nitron Ntr 40's V Ntr 46's
nitron ntr40 ntr46
533 replies to this topic
#161 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 28 June 2013 - 05:25 PM
So Nick's are essentially S1 shocks....?
#162 Exmantaa
see what your saying, but why would you need to have different shock lengths if they were right in the first place?
To get the right proportion of bump vs rebound for the ride height you have chosen whatever wheel you have and to take advantage of the full travel available.
This would be good to tailor your shocks (ride height vs. bump/droop) if the shock travel was less than the total available wishbone angle.
If you match this max window angle with the maximum shock travel (as scuffers says), you end up with only one right open/closed length. :sleep:
(Some available longer endconnections could help the people out with too short shocks, but they probably also need to add helper springs etc. in the equation... Is see a How-To topic blooming. :happy: )
Edited by Exmantaa, 28 June 2013 - 05:28 PM.
#163 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 28 June 2013 - 07:20 PM
I think so.
#164 2-20
2-20
  • 1,316 posts
Posted 28 June 2013 - 08:15 PM
not sure I understand what your saying?
I want to say that the middle point of your shock travel (for a 50/50 ratio bump/rebond) should correspond to your desired ride height.
( and still be within the window to avoid wishbone contact)
#165 Scuffers
Scuffers
  • 1,306 posts
Posted 28 June 2013 - 08:19 PM
I want to say that the middle point of your shock travel (for a 50/50 ratio bump/rebond) should correspond to your desired ride height. ( and still be within the window to avoid wishbone contact)
ah, ok.... although ideally, you need more rebound travel than bump...
#166 2-20
2-20
  • 1,316 posts
Posted 28 June 2013 - 08:38 PM
Will make no difference because the window is always constant (so I understand from reading this topic) so unless you change wishbones uprights or rear subframe. It won't matter what wheels your using or ride hight. From the other topic the bump/rebound is mainly down to vaulving and spring rate. The travel of the shock is limited to the space available. I hope I got that right haha If your car is so low that you have run out shock travel I should imagine this is a very bad thing???
Wheels sizes enter into the equation. If you change your tyres from 175/55/17 to 195/50/16 your ride height will change. If you keep the same static ride height, it means that the location of the shock piston in its stroke has been changed. Therefore the amount of bump and rebond travels have been changed
#167 2-20
2-20
  • 1,316 posts
Posted 28 June 2013 - 08:43 PM
I agree, it was just easier to explain like this...
#168 GeorgeBC
GeorgeBC
    Needs a cheaper hobby
  • 3,138 posts
Posted 01 July 2013 - 06:32 PM
Wowsers my head hurts. Im happy with my 46's and they are just vx220 spec so the same length and valved as nitron saw fit. Never heard a clonking and theres no damage/dinks in my wishbones. Ran the dampener super soft for the highland hoon on roads that should be used to test cars to destruction and apart from my tyre eating my arch liner i have no probs.
Theres about 8mm from the bottom of the wishbone to the top of the subframe. Not even sure if im looking at the right area anymore. Photo came out pretty bad but i was trying to use my finger to show the gap but it clearly didn't work.
So are they all at fault or just certain specs? I skim read bits as it started to bore me a bit so apologies if this has been covered.
#169 Scuffers
Scuffers
  • 1,306 posts
Posted 01 July 2013 - 06:48 PM
kind of meaningless without knowing the open/closed measurements... that said, open length looks reasonable (ideally, that gap should be almost nothing)
#170 Scuffers
Scuffers
  • 1,306 posts
Posted 18 July 2013 - 11:50 AM
Well, just to update this one...
Sticky's dampers are back, and yes they are longer - by some ~10mm
and as you can see, still with two bump rubbers fitted to attempt to limit the stroke - ie, they are still way too short.
Just to illustrate the difference, there's the comparison with an off the shelf EP spec Quantum
(note, this is not Sticky's)
#171 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 18 July 2013 - 12:05 PM
Thanks for tormenting me with pictures Simon :ninja:
#172 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 18 July 2013 - 05:41 PM
I love my quantum's ;-)
#173 Bumblebee
Bumblebee
  • 7,592 posts
Posted 18 July 2013 - 05:52 PM
Which ones have you gone for?
#174 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 18 July 2013 - 06:21 PM
1 ways
#175 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 18 July 2013 - 08:56 PM
Do you love Simon too? :wub:
#176 P.A.J.
P.A.J.
  • 18 posts
Posted 20 July 2013 - 06:05 AM
My 46 Nitron Track Day 1-Way with spring rates 400 & 525 Ibs/"
Posted ImagePosted Image
#177 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 20 July 2013 - 08:45 AM
You want an uprated ARB to go with those ;)
http://www.vx220.org...-anti-roll-bar/
#178 alanoo
alanoo
  • 1,324 posts
Posted 20 July 2013 - 02:06 PM
Just my two cents
Here's an old picture of my (first version) Hofmann's specs VX220 dampers
You could very easily see the length and droop issue here.
Add to that the fact that my first Nitrons did this :
way back in 2006, when I was "the first to report anything like that" according to Guy at Nitron... which said exactly the same 2 or 3 years after that when a few cases showed here...
Plus the fact my Nitron on the Atom are pure crap (so hard I couldn't even put one click from full soft without having the car rebounding like hell on track)
Must say I am really unimpressed apart by the build quality and looks...
#179 chris_uk
  • 10,060 posts
Posted 21 July 2013 - 01:33 PM
Actually, this has been kind of covered before in this thread:
(worth saying at this point it's not just Nitron that seem to have this problem).
this is the equivalent on a VX with 'old' NTR's
http://www.youtube.com/watch?v=5TK4jj3TO6Y
http://vimeo.com/38482904
this is my gaz monos droop..
#180 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 22 July 2013 - 07:35 AM
Just my two cents
Hi Alanoo
Yeah can defo see in your first pic that the tube length has been incorrectly specced there.  The Tender is doing nothing at all.  You have the same issue as Sticky which was the wrong specification was ordered (not for a VX).
As for the issues you were experiencing on your other Nitron shocks....  From what you've said above your problem is how you've set them up.  You shouldn't set Nitrons from fully soft!  It's clear in the users manual about this as past 40 odd clicks from fully hard results can be inconsistent as it's relatively unregulated.  Also your problem is a bouncy 'fast rebound' issue then you need to tighten the bump/rebound adjuster not soften them.  At fully soft of course your suspension is bouncy, thats what you've set them to be.  Try tightening them right up :) Let me know if I can be of help mate
To go more to the actual point of this thread which was meant to be NTR 40's vs NTR46's then it's clear that the earlier 40's do not necassarily have the optimum bump/rebound window as it's not within the articulation of the wishbones.
However
This issue has been rectified some time ago with the 46's design and they are a worthy development both for this reason and that the larger tube diameter and oil transfer offers much more slow bump control which equates to real confidence inspiring composure during long fast corners!
In my opinion nothing handled like my car this weekend at the National (with the possible exception of 5oclocks race car which was also on 46's).
To illustrate we took some data....
I buckled my o/s front and rear rims at Snetterton a few years ago hitting a kerb in the Time Attack final and I've not really driven the car since then until this weekend.  The car's had no geo or setup or anything since.  Just had the rims repaired and balanced.
We set up two Vbox's in two VX's at the National and SteveA took them both out for hot laps.  Steve's lap times were very consistent in both cars.  My car was consistently 1.5 seconds a lap quicker than the second car that had just come back from a full track setup and Quantum one ways fitted.  Power to weight ratio of the cars was about the same (mine being less powerful), both Supercharged (mine M62, the other Harrop), same wheels, same tyres, same brakes.
Worth saying also that both were fantastic and I'm not fighting or provoking anyone saying A is better than B more defending that there's nothing wrong with Nitrons which people seem to think.  Regardless of what people tell you is a problem the proof of the pudding is in the eating and I defy anybody to tell me my shocks are no good.
I'm happy to talk about specs and performance but I'm not getting back into a row like the other week, that did nobody any favours.
Also tagged with one or more of these keywords: nitron, ntr40, ntr46
