Quick question about the fuel tank vent pipe - which attached to the standard mani via that square connector. Seen this routed on other conversions to either the redundant MAP sensor hole in the top of the charger, or to the brass pipe on the rear of the throttle body. Was planning on the latter, but the original pipe won't reach to there (the pipe is semi rigid (steady)). Does this pipe have to be replaced with any particular type of hose? Fuel hose? Or will any rubber hose do?
cheers.
I cut that pipe/hose from that connector and use some straight rigid 8mm black plastic airpressure pipe. Connect to the connector with a piece of fuelhose and same to coal cannister solenoid. Done and OEM. ;-)
Like the sound of that. Will look into it. I think I'd rather have this connected up than open to atmosphere to be honest.
Only an hour or so for tinkering again this evening after work. Modified my 2nd hand 100A alternator as per how I've seen on here:
Put this in the car, along with the Courtenay idler pulley.
EGR valve bolts refusing to undo - so rather than force a rounded or sheared bolt, Samjeev offered to pop over tomorrow with a blow torch to get some heat on it. May also have a go at drilling out the precat on my standard downpipe. Oh and also need to fit new tensioner. Mr Samjeev may bring his Stage 4 Tubby over so I can have a go in it. Eeek!
Need to get some bolts for the SC inlet manifold support bracket - think they're M10 but didn't have any long enough.
Bit of a slow plod during the week as I'm at work, but am off next week so fingers crossed momentum will pick up then to get it done.
Edited by Steve.i.am, 16 July 2013 - 09:18 PM.
