A set of Shrek ([color=rgb(51,51,51);font-family:'Helvetica Neue', Helvetica, Arial, sans-serif;font-size:12px;]Schrick[/color]) cams maybe. Thorney seems to believe in them.
Best Compression Ratio For Itb's
#21
Posted 02 July 2013 - 08:42 PM
#22
Posted 03 July 2013 - 06:04 AM
#23
Posted 03 July 2013 - 08:00 AM
ok so we know we can run the engine with a higher compression ratio, with the help of pistons and cams. How do i think like a pro and find the optimal combination for an engine breathing through ITBs?
#24
Posted 03 July 2013 - 08:15 AM
That's probably a reason not to use them, Stg 3 comp cams are proven to produce power at high revs.A set of Shrek ([color=rgb(51,51,51);][font="'Helvetica Neue', Helvetica, Arial, sans-serif;"]Schrick[/color][/font]) cams maybe. Thorney seems to believe in them.
I'd say a big key to what you can run is the quality of the ECU and it's control or the engine as that's what allows modern OEM engines to run such high compression ratios
#25
Posted 03 July 2013 - 09:15 AM
http://www.wallacera.../dynamic-cr.php
http://www.hotrod.co...op_compression/
#26
Posted 03 July 2013 - 10:00 AM
A set of Shrek ([font="'Helvetica Neue', Helvetica, Arial, sans-serif;color:rgb(51,51,51);font-size:12px;"]Schrick[/font]) cams maybe. Thorney seems to believe in them.
Nooooooooooooo.
All show and no go IMHO
#27
Posted 03 July 2013 - 10:05 AM
or if you really want to get into it there is a single cylinder freeware version or Lotus Engine Simulation http://www.lotuscars...eering-softwareok so we know we can run the engine with a higher compression ratio, with the help of pistons and cams. How do i think like a pro and find the optimal combination for an engine breathing through ITBs?
#28
Posted 03 July 2013 - 08:19 PM
#29
Posted 03 July 2013 - 11:12 PM
A set of Shrek ([font="'Helvetica Neue', Helvetica, Arial, sans-serif;color:rgb(51,51,51);"]Schrick[/font]) cams maybe. Thorney seems to believe in them.
Nooooooooooooo.
From experience? What engine configuration?
The Schrick cams are good and give a 10 - 15 bhp gain. They work very well with the standard or 2.4 manifold and give a very good torque spread across the rev range.
If you are looking at ITB's though you can use more extreme cams to lift max power into the 7-8000 rpm range.
You reckon they are adding magic all the way to 8000RPM?
#30
Posted 04 July 2013 - 05:26 AM
I have them in my Vocky rebuilt iTB engine. She has all the usual mods: 11:1 cr, gas flowed head, balancer delete, full Tullett etc.From experience? What engine configuration?
Nooooooooooooo.
A set of Shrek ([color=rgb(51,51,51);]Schrick[/color]) cams maybe. Thorney seems to believe in them.
You reckon they are adding magic all the way to 8000RPM?The Schrick cams are good and give a 10 - 15 bhp gain. They work very well with the standard or 2.4 manifold and give a very good torque spread across the rev range.
The dyno results compared to Fab and Vocky who have Comp cams are disappointing for both torque and power.There is a triple overlay print out somewhere
#31
Posted 04 July 2013 - 08:21 AM
Nooooooooooooo.A set of Shrek ([color=rgb(51,51,51);][font="'Helvetica Neue';"]Schrick[/color][/font]) cams maybe. Thorney seems to believe in them.
it was definitely the cams causing the disappointment? Did you replace them with another brand and profile and see any difference?
#32
Posted 04 July 2013 - 08:44 AM
How does this look?
With Individual Throttle Bodies and engine running with a compression ratio of 12:1
Cams
Intake - 280°@11.2
Exhaust - 280°@11.2
Standard Springs (SAAB Head) - OK with a rev limit of 8000RPM?
#33
Posted 04 July 2013 - 08:53 AM
#34
Posted 04 July 2013 - 10:01 AM
Fab has essentially the same engine as me except for the cams so that is my conclusion.
Can't afford to change the cams to check myself.
#35
Posted 04 July 2013 - 02:41 PM
#36
Posted 04 July 2013 - 03:20 PM
Sticky Your graph is so much smoother than fans though! Fab also has 1mm over sized and waisted stem valves as well. But I agree with you one big advantage of the ITB's is the ability to use wilder cams. I think the Schrick cams are a very good road cam for this engine though.
I use my car for trackdays
Anybody want a set of Schrick cams ?
#37
Posted 05 July 2013 - 09:24 AM
Let's turn that around.. ITB's are usually needed (and bring advantages) when cam profiles become too wild to let them run on a single throttle body plenum setup.
Always found it a bit odd that the ITB development on the Z22 was historically a bit 'reversed' it seems..
What I mean to say is.. On many engines people start tuning them, porting heads, and fitting progressively wilder and wilder cams.
At a certain point the cams start to produce so many (reverse) pulses in the intake manifold plenum that they cause starvation of the other cylinders and it becomes very hard to let them idle (or you have to raise it to 1500-2000rpm) and the throttle response and general behaviour of the engine is such that it becomes a pig to drive (eg. kangarooing all over the shop)
That's the point when ITB's are usually fitted to engines.. (or twin webers in the 'olden days' )
With good mapping, a cylinder head that can support it and an engine that's set up for it an ITB equipped car can have silly duration and high lift cams in it and still idle almost as stock but rev to silly speeds (eg. a 2.0L 86x86mm version to 8000+). Or use a stroker engine and use the added displacement to get the same air velocities at a lower max rpm.
On the Z22 the initial reason for the ITB development seems to have been mostly 'the noise' I guess.. That's fine but a bit pointless from a performance viewpoint..
On the other hand, I guess it does mean that current Z22 or B207 N/A builds probably haven't reached the peak power the engine can produce by a long shot and much can still be gained/done.
Personally I like high-revving N/A engines..
#38
Posted 05 July 2013 - 12:48 PM
#39
Posted 05 July 2013 - 12:52 PM
#40
Posted 05 July 2013 - 01:35 PM
I would love to get a decent single TB plenium on my car but lack of space means it my end up giving less performance as a road car. Any on in Europe running the Dbilas manifold with the OBD tuner?
I've been running a Dbilas + a 68mm TB with an Apexi SAFC. The SAFC can compensate and I can get correct fueling up till about 6400 after which the AFR goes lean, meaning I really need adjustment on the fueling side (the SAFC alters the ECU's air flow/pressure signal). Some suggest changing to LSJ injectors. Still not a 100% solution, the SAFC is more of a hack than a proper tune. I use an Innovate LM-1 Wideband Digital Air/Fuel Kit to monitor and help tune the burn.
The OBD tuner should certainly work well and it what I be looking at if I wasn't doing an ITB build.
Edited by speedster, 05 July 2013 - 01:36 PM.
Also tagged with one or more of these keywords: individual throttle bodies, itb, compression ratio
General Discussion →
Tuning & Modifications →
Z22Se Cr & SkimStarted by speedster , 07 Feb 2015 ![]() |
Welcome to VX220.org.uk →
Introduce Yourself - Newbies & Forum Guide →
Hello From Devon, Need Forums Advice Please.Started by stevey.d , 01 Feb 2015 ![]() |
Head Gasket Thickness & Compression RatiosStarted by speedster , 04 Dec 2014 ![]() |
Best Exhaust Manifold For An Na With Itbs?Started by speedster , 16 Sep 2013 ![]() |
7 user(s) are reading this topic
Bing (2)
