Best Compression Ratio For Itb's
#41
Posted 05 July 2013 - 10:00 PM
#42
Posted 06 July 2013 - 09:05 AM
11:1 CR runs well with the standard ecu, but I am running 11.5:1 CR on my current engine with the webcon ecu.
Edited by vocky, 06 July 2013 - 09:06 AM.
#43
Posted 06 July 2013 - 09:11 AM
Yep he's in Germany at the moment,
moved on from Munich to here .....
#44
Posted 06 July 2013 - 09:19 PM
Hi vocky,
what cam profiles are you running?
#45
Posted 06 July 2013 - 09:35 PM
#46
Posted 07 July 2013 - 07:50 AM
Hi vocky,
stage 3 compcams, but they are a little mild for my 2.5 engine, tickover is way too smooth
yes, they are a nightmare to get correct, eventually arrived after three months
Just buy 'off the shelf' 11:1 CR pistons from them and skim your head if you want more.
#47
Posted 07 July 2013 - 12:32 PM
Hi vocky,
What would I need to take off to get to 12:1? What running temperatures are you experiencing at 11.5:1?
#48
Posted 08 July 2013 - 08:46 PM
I used Omega intruder pistons for an xe engine and re-bushed my con rods to suit and machined the pistons to lower the ratio
I honestly don't remember what the ratio but 12:1 sounds familiar,however I do have a thick running in gasket on and will change it at first strip down
#49
Posted 09 July 2013 - 08:54 AM
Hi Welshiejon. To quote Spock.... "interesting".
Couple of questions
What's involved in a con rod re-bush?
How much did you take off the pistons?
Does machining the pistons weaken them in any way?
Why did you use a thicker gasket? Was it for compression reasons or something mechanical?
Any custom parts or is everything off the shelf?
#50
Posted 09 July 2013 - 09:01 AM
Do you know any supplier that does high compression (9.5 or 10) 4032 alloy pistons for Z22SE Vocky? (off the shelf)
I have only found an aussie company so far, and they have the same pdf based puzzle is holding me back.
#51
Posted 09 July 2013 - 10:43 PM
From JE Pistons
[font="arial;font-size:small;"]Thank you for inquiring about JE pistons. From the looks of it, we do not offer an "off the shelf" piston kit. Therefore, we can build a custom piston for you. But before, we can build a custom piston for you, we would need for you to send us a sample piston. Generally a set of custom pistons roughly cost around $200 per cylinder and the current lead time is 4 weeks. If you have any other questions or concerns, please let me know.[/font]
[font="calibri;"][color=#ff0000;]ATTENTION: Please note our NEW shipping address below.[/color][/font]
Thanks,
[font="arial;"]Mike Le[/font]
Technical Sales
JE Pistons, Inc
#52
Posted 10 July 2013 - 06:54 AM
JE Pistons will make whatever you want, just pay them lots of money and they will arrive in a few months time
You should tell them it's for the L61 ecotec rather than a z22se
#53
Posted 10 July 2013 - 07:24 AM
accralite made me custom pistons to what i wanted for my engine, again same lead times though top work though
#54
Posted 10 July 2013 - 09:04 AM
Hi vocky, I gave them both the US and Euro engine codes. Do you have a copy of the custom order form you used for your pistons?
Hi Thealastair. What type of custom piston did you get manufactured?
#55
Posted 10 July 2013 - 11:17 AM
Response from Accralite
Hi Stephen,
[font="arial;"]Thank you for your interest in both Omega and Accralite Pistons.[/font]
[font="arial;"]We do not hold anything like this in stock, so we could look at manufacturing something for you providing you are able to accept our minimum order quantity of 20 pistons.[/font]
[font="arial;"]Kind regards[/font]
[font="arial;"]Sarah[/font]
#56
Posted 10 July 2013 - 11:19 AM
mine was low comp for a 1600 ford sigma engine
#57
Posted 10 July 2013 - 11:36 AM
[font="arial;font-size:12pt;"]Hi Stephen,[/font]
you could try to get a group buy together it's only 5 people, looking on their site you could have the advantage of getting them made in a high silicon alloy to eliminate the piston slap with most aftermarket pistons
#58
Posted 10 July 2013 - 01:49 PM
Hi Winstar. I was thinking along those lines. I was also thinking of a 12:1 CR. Anybody else out their interested?
#59
Posted 10 July 2013 - 01:58 PM
high silicon adds a new dimension
Hi Stephen,
We use 2618a as standard, anything different to this would require a separate heat treatment (and you would be looking at a minimum order quantity of 300 pistons).
Our prices for pistons out of 2618a start at £145.00 GBP each + VAT including rings, pins and clips. Our lead time at the moment is around 16 working weeks from receipt of your order.
#60
Posted 10 July 2013 - 03:14 PM
I could possibly be interested. I was planning in using Z22YH pistons and rods for my rebuild but if there's a benefit in using something with a higher CR I could be talked into it...price dependant of courseHi Winstar. I was thinking along those lines. I was also thinking of a 12:1 CR. Anybody else out their interested?
Also tagged with one or more of these keywords: individual throttle bodies, itb, compression ratio
General Discussion →
Tuning & Modifications →
Z22Se Cr & SkimStarted by speedster , 07 Feb 2015 ![]() |
Welcome to VX220.org.uk →
Introduce Yourself - Newbies & Forum Guide →
Hello From Devon, Need Forums Advice Please.Started by stevey.d , 01 Feb 2015 ![]() |
Head Gasket Thickness & Compression RatiosStarted by speedster , 04 Dec 2014 ![]() |
Best Exhaust Manifold For An Na With Itbs?Started by speedster , 16 Sep 2013 ![]() |
Bing (1)
