Edited by speedster, 15 July 2013 - 10:06 AM.
Best Compression Ratio For Itb's
Started by
speedster
, Jul 02 2013 09:35 AM
individual throttle bodies itb compression ratio
81 replies to this topic
#81
Posted 15 July 2013 - 10:05 AM
Correct, it's not the right figure.
The intake valve closing point ABDC is calculated in the following manner. Divide the intake duration by 2, add that to the lobe separation and subtract out any ground-in advance. Lastly, subtract 180 degrees.
#82
Posted 15 July 2013 - 08:04 PM
Correct, it's not the right figure. The intake valve closing point ABDC is calculated in the following manner. Divide the intake duration by 2, add that to the lobe separation and subtract out any ground-in advance. Lastly, subtract 180 degrees.
Certainly rings a bell
Also tagged with one or more of these keywords: individual throttle bodies, itb, compression ratio
General Discussion →
Tuning & Modifications →
Z22Se Cr & SkimStarted by speedster , 07 Feb 2015 ![]() |
Welcome to VX220.org.uk →
Introduce Yourself - Newbies & Forum Guide →
Hello From Devon, Need Forums Advice Please.Started by stevey.d , 01 Feb 2015 ![]() |
Head Gasket Thickness & Compression RatiosStarted by speedster , 04 Dec 2014 ![]() |
Best Exhaust Manifold For An Na With Itbs?Started by speedster , 16 Sep 2013 ![]() |
Bing (1)
