Bullocks On Way To Peaks Meet
102 replies to this topic
#1 CHILL Gone DUTCH
Posted 07 July 2013 - 11:07 AM
On way to meet point with Gordon EML light came on Code p1514 Cleared this but when I pressed accelerator supercharger was whining with no go Got it home and got code p 0107 Could this be map sensor
#2 CHILL Gone DUTCH
Posted 07 July 2013 - 11:13 AM
P0107 - Manifold absolute pressure/barometric pressure circuit low input 􏰀 Engine speed is less than 1000 rpm 􏰀 Intake manifold absolute pressure sensor voltage is less than 0.08 V or Concerned Terminals: X22: 12, 35, 58 􏰀 Engine speed is greater than 1000 rpm 􏰀 Throttle valve opening is greater than 21.9 % 􏰀 Intake manifold absolute pressure sensor voltage is less than 0.08 V And P1514 - Electronic Throttle Control Malfunction 􏰀 The control unit recognises the malfunction of the circuit via an internal evaluation logic. Concerned Terminals: X22: 12, 35, 58
#3 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 07 July 2013 - 11:24 AM
Not certain, worth checking the connectors by the header tank, maybe contact cleaner first Did you go Tmap? I have a spare almost new map sensor if needed.
Edited by NickB777, 07 July 2013 - 11:26 AM.
#4 CHILL Gone DUTCH
Posted 07 July 2013 - 11:29 AM
Yes
This one
http://www.courtenay...2/prod_803.html
Is there a way of running in perminant open loop with Dutch ECU
#5 NickB787
NickB787
  • 7,813 posts
Posted 07 July 2013 - 11:34 AM
Yes that's the sensor, I am just reading the manual now, not certain
#6 CHILL Gone DUTCH
Posted 07 July 2013 - 11:37 AM
Nick at what point would/could I use 2.5 bosch map sensor?
#7 Arno
Arno
  • 1,238 posts
Posted 07 July 2013 - 11:39 AM
AFAIK OBDtuner runs the engine on speed-density (MAP) so you need a properly working sensor for it to run OK. It may fall back on alpha-N (TPS) as a failsafe, but that's about it..
Sounds a lot like something is wonky in the MAP sensor wiring or it's readout as the ECU code for the electronic throttle is also quite picky about what it sees as 'acceptable' values for a throttle-position  and pressure range, so both codes are probably related and share the MAP sensor as a common element.
Do a datalog and see what values the MAP is returning and if they are sane or not?
You do have an ECU and software now that can datalog you know ;)
#8 NickB787
NickB787
  • 7,813 posts
Posted 07 July 2013 - 11:45 AM
The way I read it you can use a 2.5 Tmap sensor at any time just stay under 1.5 bar boost if you are going to do more than that then put a 3.0 bar sensor in
#9 CHILL Gone DUTCH
AFAIK OBDtuner runs the engine on speed-density (MAP) so you need a properly working sensor for it to run OK. It may fall back on alpha-N (TPS) as a failsafe, but that's about it..   Sounds a lot like something is wonky in the MAP sensor wiring or it's readout as the ECU code for the electronic throttle is also quite picky about what it sees as 'acceptable' values for a throttle-position  and pressure range, so both codes are probably related and share the MAP sensor as a common element.   Do a datalog and see what values the MAP is returning and if they are sane or not?   You do have an ECU and software now that can datalog you know ;)   Bye, Arno.
Yes good call Arno, I'm going to get multi meter out make sure I've got 5v input.
#10 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 07 July 2013 - 11:46 AM
Yes
This one
That's not a t map that is a standered 2bar map sensor
#11 chris_uk
Posted 07 July 2013 - 11:47 AM
interestingly i had the same issue lee, mike and yourself have been having and i only run 1bar of boost.
#12 CHILL Gone DUTCH
Posted 07 July 2013 - 11:49 AM
I've got a question from a idiot But here goes. How do you work out boost??
#13 NickB787
NickB787
  • 7,813 posts
Posted 07 July 2013 - 12:09 PM
1.5 bar is 21.7 psi Not certain what size pulley you have but will depend on that
Edited by NickB777, 07 July 2013 - 12:10 PM.
#14 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 07 July 2013 - 12:10 PM
Fit a boost gauge you should no what boost from the size pulley you are running on the m62 but all cars are a little different .
#15 CHILL Gone DUTCH
Posted 07 July 2013 - 12:11 PM
Sorry I need to no how to work out the presure
#16 CHILL Gone DUTCH
Posted 07 July 2013 - 12:13 PM
It's a m62 3.1 pulley charger has some minor porting Is there a way of working it out or do I need boost gauge
#17 smiley
Posted 07 July 2013 - 12:25 PM
Historically the 1514 was generated by:
- scangauge set to showing more then 3 values - faulty injector - faulty map sensor
Where 3 is the most common one on this code.
#18 CHILL Gone DUTCH
Posted 07 July 2013 - 12:27 PM
Historically the 1514 was generated by:   - scangauge set to showing more then 3 values - faulty injector - faulty map sensor   Where 3 is the most common one on this code.
That's interesting only put scanguage back in today, Can you explain moor
#19 techieboy
Posted 07 July 2013 - 12:32 PM
Thanks, ordered and installed Torque Pro to my phone.   Hopefully will capture some data
    thumbsup   In order to get added boost values from your MAP sensor, assuming it's measured in kPa as it is on the NA, you subtract 100kPa (which is the background atmospheric pressure) from the absolute reading and then multiply by 0.14503773773020923 (probably don't need that level of accuracy :lol: ) to get the actual added boost (i.e. what a boost gauge would display) in psi. Or multiply the kPa figure (less the 100kPa) by 0.01 to get the added boost in bar.
My SC produces ~13.5psi of boost with a 2.9" pulley fitted and I'm still running the original Courtenay MAP sensor from when they did the conversion 4 years ago and have never had the issue despite presumably being at the very very edge of what that sensor can support. I used to get the same problem on my NA when I was trying to run the 68mm LSJ throttle body with the 2.4 inlet manifold. Never solved the problem and abandoned it for the SC conversion. P1514's are mainly caused by the loom of doom so definitely check that's all secure. You need to bin that MAP sensor and fit the 2.5 bar or 3.0 bar TMAP sensor and do the necessary loom mods to run it and then reconfigure OBDTuner for it.
#20 smiley
Posted 07 July 2013 - 12:42 PM
Mark Verboom (http://www.verboom.n...ster/index.html figured this out at some point, many moons ago.
May i suggest to clear the code, disconect the scangauge and go for a blast to verify?
