Bullocks On Way To Peaks Meet
#41
Posted 07 July 2013 - 05:50 PM
#42
Posted 07 July 2013 - 05:52 PM
#43
Posted 07 July 2013 - 06:08 PM
Does anyone no if the bosch 0 261 230 042 has the same plug as the Delphi 2.0 bar
No, the 2.5 bar and 3.0 bar sensors are 4 wire (it measures two functions and not one, like the regular MAP) and not the 3 wire connection that the standard MAP sensor uses. Instructions for wiring the TMAP sensor into the standard IAT sensor and MAP sensor circuits are in the OBDTuner manual or in a couple of threads on here over the last two weeks.
#44
Posted 07 July 2013 - 06:09 PM
#45
Posted 07 July 2013 - 10:32 PM
Just for information pressure was up at 1032mb when I arrived tonight, highest it's been for some time.
Get the TMAP sorted, hopefully sort it.
Edited by NickB777, 07 July 2013 - 10:32 PM.
#46
Posted 08 July 2013 - 06:08 AM
Yes its been tipped over the edge by the air pressure by the looks of things,
#47
Posted 08 July 2013 - 07:13 AM
OK a bit of research this morning looks like the 3.0bar bosch (0281002437) TMAP is ready available from vectra 1.9CDTI and saab9-3 2.2TiD
going to go to the breakers to see if they can sort a plug out for me
#48
Posted 08 July 2013 - 08:24 AM
old lambda plugs will do
#49
Posted 08 July 2013 - 08:39 AM
That was for info only, it shouldn't have any effect on the sensor.
Just sounds like the map sensor has failed did you want to try a direct replacement first or are you just going to put the
TMAP sensor on? I would be nice to know that in fact was the cause before making changes.
#50
Posted 08 July 2013 - 08:51 AM
#51
Posted 08 July 2013 - 08:58 AM
yes thats the way I read it also.
When you do rewire it though I wonder if you should do a learning run again, as you are now taking the air temp post compressor and it's going to be higher.
Did you want me to send you a spare map sensor?
Edited by NickB777, 08 July 2013 - 08:58 AM.
#52
Posted 08 July 2013 - 09:01 AM
#53
Posted 08 July 2013 - 09:08 AM
Pm me your address and I will get it out
yep I was meaning after your rewire the IAT part
Edited by NickB777, 08 July 2013 - 09:10 AM.
#54
Posted 08 July 2013 - 09:12 AM
#55
Posted 08 July 2013 - 09:13 AM
I would like to get it working first do I know that look etc are okWhy dont you just get the 2.5bar map sensor they put on stage 2/3 conversions and be done with it?
#56
I think I have 2 spare 2.5bar tmap sensors also
I could send you both get it running with the normal map sensor, then change to the tmap once your happy everything is ok.
Edited by NickB777, 08 July 2013 - 09:15 AM.
#57
Posted 08 July 2013 - 09:14 AM
Have you got lambda plug toI think I have 2 spare 2.5bar tmap sensors also
#58
Posted 08 July 2013 - 09:16 AM
got an old loom here somewhere, will check to see if there is a plug on it.
#59
Posted 08 July 2013 - 09:17 AM
Night in shinning armourgot an old loom here somewhere, will check to see if there is a plug on it.
#60
