I dont understand tbh. If you know its the map sensor why are you trying to get it working? When you can just fit one that will work and then map that one up. (I havent read the thread so there is probably another reason so forgive me)I would like to get it working first do I know that look etc are okWhy dont you just get the 2.5bar map sensor they put on stage 2/3 conversions and be done with it?
Bullocks On Way To Peaks Meet
#61
Posted 08 July 2013 - 09:18 AM
#62
Posted 08 July 2013 - 09:20 AM
#63
Posted 08 July 2013 - 09:23 AM
agree fix the problem first, i.e try the MAP sensor if it does work ok then you can change to a TMAP, if it doesn't get the car running first ok then make changes.
#64
Posted 08 July 2013 - 09:39 AM
Edited by oakmere, 08 July 2013 - 09:42 AM.
#65
Posted 08 July 2013 - 09:41 AM
#66
Posted 08 July 2013 - 09:46 AM
#67
Posted 08 July 2013 - 09:50 AM
Yes checked them also engine ticks over and works for 2 boostsAlso Smiley said it could be injector connection related and you have recently changed these have they been checked?
#68
Posted 08 July 2013 - 09:51 AM
#69
Posted 08 July 2013 - 11:16 AM
#70
Posted 08 July 2013 - 11:30 AM
When we first installed the harrop I had loss of throttle after a high speed run i.e hard acceleration through the gears, I was running about 320bhp on the normal map sensor everyone uses now. This bit will sound strange but once we relocated the IAT sensor further away from the TB I never had the issue again don't ask me why it worked but it did.
#73
Posted 09 July 2013 - 10:12 AM
is it the map sensor which is indicating 206Kpa,
even though i havent seen over 200 previously actually only 180Kpa
#74
Posted 09 July 2013 - 10:26 AM
What pulley are you on? (and exhaust?)
That is quite some boost pressure for an M62 SC... Maybe you have a clogged cat?
#75
Posted 09 July 2013 - 10:28 AM
im running a 3.1 pulley
#76
Posted 09 July 2013 - 10:34 AM
just checked previous logging sessions and the most i have ever seen before is 181KPA
#77
Posted 09 July 2013 - 10:45 AM
I remember you had a 3.1 fitted. And ~0.8 bar boostpressure sounds more normal for a Stage 2+ SC.
Your 206KPa reading probably triggers the fault; being a faulty MAP sensor or maybe a clogged exhaust system (cat)...
#78
Posted 09 July 2013 - 10:46 AM
interesting,
the whine from the charger even happens now when car isnt moving in neutral so maybe the pressure from the cat is causing resistance
#79
Posted 09 July 2013 - 10:47 AM
exhaust is a tullet
#80
Posted 09 July 2013 - 10:52 AM
interesting,
There's definitely a blockage somewhere. My M62 generates 13.5psi on a 2.9" pulley and as annoying as the banshee wail is from the small pulley, it only happens on WOT with the engine under load.
Tullett 3.0" system with no cat.
