Bullocks On Way To Peaks Meet
102 replies to this topic
#81 smiley
Posted 09 July 2013 - 10:55 AM
exhaust is a tullet
You may want to inspect the cat section, which is starting to become a known problem with tullett.
#82 CHILL Gone DUTCH
Posted 09 July 2013 - 10:58 AM
Oh sh*t,
and only a week and a half to the national
#83 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 09 July 2013 - 11:02 AM
Oh sh*t,
yep I know the feeling.
does seem high boost, maybe take the cat section off just to be certain
PS PM Techieboy sent
Edited by NickB777, 09 July 2013 - 11:04 AM.
#84 CHILL Gone DUTCH
Posted 09 July 2013 - 11:08 AM
Going home now I'm going to take it off What are the chances of getting a decat asap
#85 NickB787
NickB787
  • 7,813 posts
Posted 09 July 2013 - 11:10 AM
Mine is up at Jims right now..... your best bet if Tullet can't sort it is to get it done local, go for a 200 cell sports CAT, or get a decat pipe made up so you can do the national, and lucky for you you have software which will save you a drive to Norfolk to get the car mapped.
Edited by NickB777, 09 July 2013 - 11:11 AM.
#86 techieboy
Posted 09 July 2013 - 11:22 AM
And better yet, will allow you to turn off the warning from the post-cat sensor, so no cheater/simulator needed to prevent EML's (though of course you'd never consider running without a cat). ;)
#87 CHILL Gone DUTCH
Posted 09 July 2013 - 11:32 AM
if it gets me to the national i will do anything :)
#88 Exmantaa
Posted 09 July 2013 - 11:44 AM
You don't have the OEM 2.2 downpipe section (minus pre-cat) lying around for a temp. fix?
#89 smiley
Posted 09 July 2013 - 11:47 AM
And ducktape the gap between 2" and 2.5" :huh:
#90 CHILL Gone DUTCH
Posted 09 July 2013 - 01:07 PM
It's the cat
#91 2deano5
2deano5
  • 668 posts
  • Interests:Cars / Squash
Posted 09 July 2013 - 01:11 PM
meow,  :P
On a side note your last two pages have convinced me I'm going Dutch :)
Good luck :)
#92 CHILL Gone DUTCH
Posted 09 July 2013 - 01:22 PM
im going to try and get the remainder of the cat out of the pipe and run it like that,
will this make it LOUDER
#93 CHILL Gone DUTCH
Posted 09 July 2013 - 01:23 PM
meow,   :P
Good luck :)
Its the future but dont tell anyone its a secret
#94 NickB787
NickB787
  • 7,813 posts
Posted 09 July 2013 - 01:44 PM
glad you know what it is
#95 techieboy
Posted 09 July 2013 - 01:45 PM
Yes. But probably not massively, given the wall of noise the Tullett already produces.
#96 CHILL Gone DUTCH
Posted 09 July 2013 - 01:55 PM
#97 CHILL Gone DUTCH
Posted 10 July 2013 - 11:28 AM
could you explain more about what i have to turn of post cat please now i have taken the CAT out before i switch on
Edited by CHILL Gone DUTCH, 10 July 2013 - 11:33 AM.
#98 techieboy
Posted 10 July 2013 - 11:37 AM
In the OBDTuner parameters tab, there's an option to set Catalyst Check to enabled or disabled. If it's set to disabled it won't bother doing anything with the readings from the post-cat lambda sensor (which is basically only there to confirm that the cat is installed and working) and won't throw up an error code to saying "whoah, wait a minute, something's up with catalyst or second lambda".
Just leave your post-cat lambda installed and hooked up and set it to disabled in OBDTuner (though it looks like that might be what your's is set to anyway).
#99 CHILL Gone DUTCH
Posted 10 July 2013 - 11:43 AM
In the OBDTuner parameters tab, there's an option to set Catalyst Check to enabled or disabled. If it's set to disabled it won't bother doing anything with the readings from the post-cat lambda sensor (which is basically only there to confirm that the cat is installed and working) and won't throw up an error code to saying "whoah, wait a minute, something's up with catalyst or second lambda".   Just leave your post-cat lambda installed and hooked up and set it to disabled in OBDTuner (though it looks like that might be what your's is set to anyway).
It's disabled cheers, Is that where I could put a wideband in
#100 techieboy
Posted 10 July 2013 - 11:51 AM
Well, you could stick a wideband into the exhaust in place of the second lambda in your current setup and wire it into the defunct EGR circuit for logging. But the wideband sensor usually needs to be installed pre-cat, so it would only be any good whilst you're running without the innards of your catalytic converter. Assuming you do take the exhaust apart again in the future to get a new cat welded in, get whoever does it to add an additional bung before the cat for a wideband to be installed properly.
