After a lot of forum searching I finaly fixed my recirc issue, it was a leaky vac box. The turbo no longer stalls and gives the turkey noise which is good but now I have a new problem.
With a leaky vac box it used to over boost to about 1.25 bar and settle at about 1 bar in third gear and above. Now it over boosts to 1.4 bar and settles at 1.1. My plan was to give the car 3 runs and hope the ECU would re-learn and the boost would settle down. On the first run all was OK until I planted the accelerator in third gear at low revs. The boost level built up slowly then whipped round to 1.5 bar, the boost immediately dropped off to 0.8 bar then settled at 1.1.
My questions are:
how many times can I boost this high without damaging then engine?
is the ECU likely to re-learn and return to the original boost levels or should I just reset it?
Thanks in advance, Pete.
