Norwegian Trackday Speedster
82 replies to this topic
#1 Stig_1911
Stig_1911
  • 121 posts
Posted 23 July 2013 - 10:06 AM
So far I have done the usual uppgrades:
46mm Nitron trackday shocks
EP 1" anti rollbar
TD 8"-9" x 17 Wheels, toyo 888's
Fcr setup for rear brakes
300bhp dbilas turbokit, wtih extra oil cooler and upprighter valve springs
geo
Things to come
Rollcage
GMs bodykit
But I need some help...... I picked up my car last week at dbilas....it ran like a dream......had it round the nordschleife,and some serios "crusing" in the surounding area of adenau.....On my way home from Germany I got the coolant warning light :excl:  :excl:  :excl:  ... water in oil, and oil in water.... :angry2:  :angry2:
So guess I have blown my head gasket...... So its time for a engine rebuild.......
Questions :- Are the eagle rods,wiseco piston combo good enough or should I go for ZRP rods and wøssner pistones.?
                   - where can i buy Neutral Balance Shafts  zzp is out of Stock.
Any sugestions for parts and supplyers for the engine rebuild is very helpfull :blush:
Cheers Stig
#2 vocky
Posted 23 July 2013 - 10:10 AM
check the oil cooler first, very unlikely to be the head gasket
#3 techieboy
Posted 23 July 2013 - 10:12 AM
Then check the cylinder head hasn't cracked after removal/insertion of a spark plug.
#4 fezzasus
Posted 23 July 2013 - 10:18 AM
Are you running 300 bhp on standard conrods and pistons? The limit for the conrods is usually 250-270 bhp
#5 oakmere
oakmere
  • 2,143 posts
Posted 23 July 2013 - 07:31 PM
Neutral rods not needed, just do a full delete! No running or reliability issues this way. Might get away turbo 300bhp on std rods and pistons for road but not track. 270 max for SC not including the 30bhp to drive the SC it's self.
#6 Stig_1911
Stig_1911
  • 121 posts
Posted 25 July 2013 - 12:31 PM
Tested the oil cooler With 4 bars of pressure , no leaks,did a compression test on the head all cylindes got upp to the same pressure, one of the cylinders used a little more time to build the same pressure, sparkplugs ok.  Car runs fine on idle, noe black or white smoke.... Since the oilcooler is ok, then it can't anything else than the head gasket.....
Then I think its time for a Complete engine rebuild: New rods,low compression pistones,lighten flywheel, New clutch,main bearings,valves cams,porting etc.
Any recomandations of witch parts to use in a 2.2 turbo build???
#7 vocky
Posted 25 July 2013 - 04:27 PM
z22se engine has 9 Bar of oil pressure, so 4 Bar isn't enough to prove the oil cooler is okay.
I have yet to hear of a z22se head gasket failing unless the engine has been run without any coolant :huh:
#8 Stig_1911
Stig_1911
  • 121 posts
Posted 25 July 2013 - 06:30 PM
Okay, will get it pressure cheked tomorrow...... the engine has not been run without coolant.
#9 vocky
Posted 25 July 2013 - 09:06 PM
there have been many leaking oil coolers on vx220 / speedsters, but only one head gasket failure - due to no coolant
as for an uprated engine, use this sc engine build as a guide http://www.z22se.co....ne-build.12272/
#10 speedster norway
speedster norway
  • 162 posts
Posted 26 July 2013 - 08:42 AM
And about the balance delete try this.http://www.levelzero...01f323b86a6a7e0
And here are DIY..http://www.j-body.or...432339&t=432339
Or the best way delete the chain and use a electric water pump.http://www.daviescra...07-details.aspx
I have use a electric pump the last year on my 2,2 NA.
#11 Stig_1911
Stig_1911
  • 121 posts
Posted 17 November 2013 - 09:20 PM
Little uppdate..
This is where it Started...
Some sencible uppgrades later.....TD's,Nitrons,Brakes,EP rollbar, the 300bhp Dilbert kit... Happydays at the Nurburgring
7 days of happiness.........   third time around..... it' hard when you don't know the turns....
until... engine failure.... 20 cm crack in the cyliderhed..... and brown guuuee every in the engien..... so back on the wagon.... :wacko:
Engine is dismanled... crank is on its way to vocky so it can start a new life in spanking new Saab engie :D  :D  :D  with compcams stg2 turbo cams,supertec valves,light flywheel,uprated competition clutch from courtenaysport, dazzled  with som vocky magic.....
When I get back from work in about 14 days, i will start with the Gms bodykit... pictures of progress will follow soon.....
Edited by Stig_1911, 17 November 2013 - 09:28 PM.
#12 Stig_1911
Stig_1911
  • 121 posts
Posted 17 November 2013 - 09:24 PM
Goal engine wise.... near 400bhp..... any thoughts regarding fuel pump....a 255 or a 450???
#13 Stig_1911
Stig_1911
  • 121 posts
Posted 09 December 2013 - 08:30 PM
Some drawings of trigger wheel and Sensor bracket
#14 techieboy
Posted 09 December 2013 - 08:32 PM
Nice. Very neat way to mount the bracket for the crank sensor. Impossible to fit that incorrectly. :D
#15 vocky
Posted 09 December 2013 - 08:40 PM
looking good  :D
#16 Stig_1911
Stig_1911
  • 121 posts
Posted 09 December 2013 - 08:57 PM
Ideas for mounting on top of the exiting cover plate is: If you don't want to machine the Pulley, the just shim the bracket and the trigger wheel eaqually.. the triggerwheel can be andjustet 2mm each way in rotation.... It's hard to measure on the cover... but I expect You would need max 1 mm of adjustment...
#17 Tony H
Tony H
    Lotus on Crack
  • 1,729 posts
Posted 09 December 2013 - 09:03 PM
Why not make the bit that goes over the cover plate solid so it can replace the existing cover plate?
#18 vocky
Posted 09 December 2013 - 09:17 PM
good idea, saves a little production time too  :happy:
Edited by vocky, 09 December 2013 - 09:18 PM.
#19 Stig_1911
Stig_1911
  • 121 posts
Posted 09 December 2013 - 09:49 PM
That can I can do....
#20 Tony H
Tony H
    Lotus on Crack
  • 1,729 posts
Posted 09 December 2013 - 09:52 PM
And weight!!! :)
Saves need for loner bolts too. I am a genius.
Edited by Tony H, 09 December 2013 - 10:00 PM.
