Norwegian Trackday Speedster
82 replies to this topic
#61 BB155_748R
BB155_748R
  • 4 posts
Posted 09 July 2015 - 08:44 PM
Since "some bits" of me are one some of the photos, and my brother now need a kick in is ass to do some updates here and on the car.
(He has been to busy with work and no spare time)
So here's  an update :
Chasis painted and cleared, the rest is still at the painter .... (who stated the car would be ready 6 weeks ago....., but the painter is off to Sweden for another rock festival)
The rolling chasis is collected and in his "secret lair".
Lots of boxes with parts has turned up over the winter.....
He stared fiberglassing the font splitter, yesterday ........... (this and ducting for the brake cooling is what is left of fiberglass fab)
Will lend him  a hand over the weekend to get the gearbox out of the car, so the LSD can be fitted.
#62 Stig_1911
Stig_1911
  • 121 posts
Posted 24 June 2016 - 07:32 PM
Little uppdate, engine and gearbox, with lsd fittet, And finaly after almost 2 year of waiting the car is painted chinky chinky
Edited by Stig_1911, 24 June 2016 - 07:37 PM.
#63 TFD
TFD
  • 607 posts
Posted 24 June 2016 - 08:46 PM
That stuff looks tha bom.. looking forward to the finished product.
#64 Nev
Posted 01 July 2016 - 05:36 AM
Oh, GMS clams. How are you going to get the wheels to fit under the arches? Are you just going to lower the suspension?
#65 Stig_1911
Stig_1911
  • 121 posts
Posted 01 July 2016 - 12:09 PM
Plan is to get Eliseparts race GT upprights , and also mount airlift kit )to my coilovers in all four corners from http://www.stance-so...ons.com/static/ so i can raise the suspension when needed...
#66 Nev
Posted 01 July 2016 - 04:19 PM
The expensive but correct method !
What airlift kit are you looking at - got a link ? Won't it be heavy and hard to fit in there?
Edited by Nev, 01 July 2016 - 04:22 PM.
#67 Stig_1911
Stig_1911
  • 121 posts
Posted 30 July 2016 - 07:34 PM
Little uppdate from the cave....Made a new  "subframe" for rear bodywork, mocked up ducting..
Test fitted rear clam... think it looks nice....
#68 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,515 posts
    "Yes, I built it"
Posted 31 July 2016 - 07:17 AM
Very different but will be good to see temperature outcome
#69 smiley
Posted 31 July 2016 - 07:44 AM
Which ducting will feed the 4 plastic scoops?
#70 Stig_1911
Stig_1911
  • 121 posts
Posted 31 July 2016 - 01:35 PM
There is a naca duct in each turbo ear, and two naca ducts on top of real clam, Will be using alot of zircotec heatsheilds to try to get the temperature down in the IC area.... and if IT dosent work then I Will god for charge cooling
#71 BB155_748R
BB155_748R
  • 4 posts
Posted 08 May 2019 - 11:12 AM
Project is starting up again, (giving my brother a helping hand)
As always clearance issues :
heater Feedpipe on therrmostat housing :
Have some clearance issues with the Heater Feedpipe on the Thermostat housing. (New Turbo manifold for Topmont turbo.)
Can this be plugged ont the thermostat hosing and relocated to the block to radator water pipe using a "T off".
Will this cause any issues. (Heater return left in place where it is on the termostat housing).
Turbo downpipe (2.2)
How much clearace downpipe to frame is needed (new downpipe needs to be fabricated),
#72 Stig_1911
Stig_1911
  • 121 posts
Posted 05 July 2019 - 02:30 PM
Little uppdate from the North
Started to put the car toughter, and little problems starts popping up.  Water line from termostate housing faults the exhaus manifoild,
https://photos.app.g...aWop7kwjsEfm8v5
to be continued.... have to find a way to post pictures...
Edited by Stig_1911, 05 July 2019 - 02:35 PM.
#73 Stig_1911
Stig_1911
  • 121 posts
Posted 05 July 2019 - 02:54 PM
Edited by Stig_1911, 05 July 2019 - 02:55 PM.
#74 Stig_1911
Stig_1911
  • 121 posts
Posted 05 July 2019 - 03:01 PM
I have modified my dilbert intake manifoild with a spacer to use it with 68mm throttle boddies.Result I had to make a 20mm phenaholic spacer to get clearace..
Startet with This 20mm ptfe plate
https://i.imgur.com/oFv7xra.jpg
And some elbowgrease..... ended up with this
Edited by Stig_1911, 05 July 2019 - 03:03 PM.
#75 Stig_1911
Stig_1911
  • 121 posts
Posted 05 July 2019 - 03:14 PM
Next task ...I made a lot of these triggerwheels som Years ago.....
It fits the standard crank pulley.... bu I canged my mind a month ago and went for a ATI underdrive pulley..... And it o fcause doesn't fit my triggerwheel, so I had to get a adapter made up..
And a Senoor bracket
From this :
Edited by Stig_1911, 05 July 2019 - 03:16 PM.
#76 Stig_1911
Stig_1911
  • 121 posts
Posted 05 July 2019 - 03:18 PM
Next up Painted the rear subframe, wishbones width por15 and changed for EP eractal bushings
#77 Stig_1911
Stig_1911
  • 121 posts
Posted 05 July 2019 - 03:20 PM
#78 Stig_1911
Stig_1911
  • 121 posts
Posted 05 July 2019 - 03:26 PM
The corbeau seat le pro is a pita to fit inn a left hand drive car  in the drivers position,the seat doesn't fit the seat rails so I had to weld it in place, paasenger side fits...
#79 Stig_1911
Stig_1911
  • 121 posts
Posted 05 July 2019 - 03:34 PM
Intercooler plumbing finnished.... with silicone couplers..... But I will welding the pipes so I Just have silicone in the ends...
#80 Stig_1911
Stig_1911
  • 121 posts
Posted 05 July 2019 - 03:42 PM
Will be making a new downpipe  from the turbo to the cat in 3 inch stanless,to fit to my exsisting 2.5 exhaust(the 2.5 exhaust have e marking and tuv).,  as soon as my welding skills are up for it.... bought a TIG AC/DC Welder a  month back.  So my plan is to finnish the exhaust in the next couple of days...5nQAm7W.jpg​
