Norwegian Trackday Speedster
82 replies to this topic
#81 Stig_1911
Stig_1911
  • 121 posts
Posted 05 July 2019 - 03:49 PM
Things on the list:
Fit Garv Dash
Fit Racelogic traction control
Fit EP big brake kit
Fit   raceUpprights from ........
Fit  Toelinks with bracebar from spitfire
Fit air cups, and compressor...
Been hording bling bling for a while...
I have to do it stages so I can get my car road legal..... and that will be a hassle here in Norway.... so I'm crossing my fingers that I don't have to take my car to Germany and do a emission cycle test(same test as diesel gate) go figure....
Some pictures from the pit...
Edited by Stig_1911, 05 July 2019 - 03:59 PM.
#82 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 06 July 2019 - 06:24 AM
Very nice work.
Nice you get some decent wheels on it too.  :-)
Br, Per
#83 Arno
Arno
  • 1,238 posts
Posted 06 July 2019 - 10:56 AM
The corbeau seat le pro is a pita to fit inn a left hand drive car  in the drivers position,the seat doesn't fit the seat rails so I had to weld it in place, paasenger side fits...
AFAIK Corbeau changed the shells and the current seats are meant to be fitted on the later (Toyota-)Elise seat rails from around 2007 onwards.
Earlier Corbeau seats were based on the S1 Elise so the seat rails from these (and the 340R for double-shear seatbelt mounts) worked.
Having said that.. They often are a bit 'difficult' fitment wise as Corbeau doesn't seem to be able to keep the dimensions of the seat shells themselves correct (too narrow or too wide, irregular shape, etc.) and often the threaded inserts in the seat shells are bonded in at an angle or offset by several mm in some direction so even seat rails that are supposed to fit tend to need 'modifications' to work.
Seems that the jigs/moulds they use to make the seat shells are not very good.
