Nitron 40's Open Length Issues
174 replies to this topic
#41 2-20
2-20
  • 1,317 posts
Posted 01 August 2013 - 01:54 PM
@ Paul, did you buy new springs too as an extra, or is the blue "rfurbisched to 2013 spec"??
@ John T; what's wrong with your fronts? Front has a bracket, so you're very flexible there to get things right.
(I just lowered my front bracket 6mm to get my "325 NTR's" height spot on with a 425lb spring...)
Butthe front had a very limited stroke .
Aren't the new specs better on this field ?
#42 PaulCP
PaulCP
  • 6,066 posts
Posted 01 August 2013 - 02:56 PM
@ Paul, did you buy new springs too as an extra, or is the blue "rfurbisched to 2013 spec"??)
Sorry, should have been clearer, yes I had new springs put on since, on testing, one of the fronts had weakened
#43 Scuffers
Scuffers
  • 1,306 posts
Posted 01 August 2013 - 04:24 PM
OK, before we all go and proclaim the second coming etc...
I still don't see in plain numbers exactly what is being proposed here?
Way I see it is this, all the ones out there are either 395 or 402mm open length (pre/post 2010?)
In an ideal world, these need to be all changed to make them 430mm open length (or there abouts).
is this what is being proposed?
#44 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 01 August 2013 - 05:17 PM
OK, before we all go and proclaim the second coming etc...   I still don't see in plain numbers exactly what is being proposed here?   Way I see it is this, all the ones out there are either 395 or 402mm open length (pre/post 2010?)   In an ideal world, these need to be all changed to make them 430mm open length (or there abouts).   is this what is being proposed?
Please Simon, I started this thread to get away from you. We're doing fine without you so unless you have something positive to add could you confine your comments to the other thread.
#45 Scuffers
Scuffers
  • 1,306 posts
Posted 01 August 2013 - 05:34 PM
Oh do give it a rest and just answer the question can't you?
the last thread only got to 20+ pages cause your refusal to (1) see the problem and (2) accept there was something wrong.
Now you appear to be trying to act the hero all of a sudden....
Why cant you just be straight and honest about it all? your expecting people to spend yet more money, they have a right to know EXACLY what is being proposed don't you think?
ie.
'we are looking to get some new longer end eye's made up that will take the open length to XX mm, these will cost £X,
this will allow you to run anything from X-Y mm ride heights (based on std wheels/tyres)
if you don't already have tender springs, then your ideally going to need some (with separators) at a cost of £X'
see?
how hard is that?
#46 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 01 August 2013 - 05:48 PM
Yet again the only person with a problem is Simon.... The people effected are happy with the progress and the focus so I'm not going to get dragged into another one of your rows. This thread does not concern you.
#47 Scuffers
Scuffers
  • 1,306 posts
Posted 01 August 2013 - 06:26 PM
lol! get you!
#48 PaulCP
PaulCP
  • 6,066 posts
Posted 01 August 2013 - 06:59 PM
Scuffs, if you have a personal problem with Jimmy take it off line, grow up and stop acting like a spoilt brat
#49 Scuffers
Scuffers
  • 1,306 posts
Posted 01 August 2013 - 07:03 PM
lol.. it's nothing personal, more a case of lack of transparency and the simple risk of people getting tucked up yet again. i feel like this whole saga has been a case of dragging jimmy along kicking and screaming. the other thread could have been sorted in 2-3 pages without the blanket denials and sales patter...
#50 JohnTurbo
JohnTurbo
    SuperScruff
  • 3,635 posts
  • Interests:Performance cars!
Posted 01 August 2013 - 07:20 PM
...right so fronts are 320mm open length. Im back on stock shockers, and off to do some green laning. Lol
#51 PaulCP
PaulCP
  • 6,066 posts
Posted 01 August 2013 - 07:21 PM
Well I think we've all got the message now so probably time to give it a rest!
#52 JG
JG
  • 13,617 posts
Posted 01 August 2013 - 09:41 PM
So what about 411's (I think that's what mine are) rework or not?
#53 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 01 August 2013 - 10:04 PM
Depends what the open length solution is.... I'd say you're on the cusp.... Probably around 58mm of droop (at wheel) from -15mm ride height.... So nowhere near the issues the 395's have but not amazing.
#54 TazN
TazN
  • 2,931 posts
Posted 02 August 2013 - 12:02 PM
Jimmy - no I've not measured them yet. for that the vx would have to be moved and I cba after work. it's coming out on Sunday for a meet so will get me ruler out then.
I'm probably similar to JG's so depending on what the solution ends up bringing them to then I'd go for it when they next need servicing - hence my question of would Nitron do this in say 2 years (for example) when they next need a service.
#55 Bumblebee
Bumblebee
  • 7,592 posts
Posted 02 August 2013 - 06:02 PM
Il hopefully have some measurements done on Monday but I think mine are going to be 395
#56 P11 COV
P11 COV
  • 7,686 posts
Posted 02 August 2013 - 06:21 PM
I'd be keen on option 2 as I've been intending a refurb anyway. I shall probably want new (and different) springs also.
Matt Bentely mentioned that he's been talking to Nitron about a solution too. How does this fit with that? Is it the same thing?
#57 2-20
2-20
  • 1,317 posts
Posted 03 August 2013 - 10:00 AM
Option 2 for me too, but what about the valving  if i don't have the springs rates usually coming with the Nitrons specs ?
Edited by 2-20, 03 August 2013 - 10:01 AM.
#58 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 03 August 2013 - 10:14 AM
I think Matt was looking at manufacturing a solution with Nitron but I'm not exactly what's going on with that.....
Whenever people want a refurb then I'm sure it'll be ok.  I'll make sure it's setup with my new contact within the business.  It's not time to go yet though guys, just bear with us a little longer and I will come back with some firm options etc :)
Given the age like Sizten said it seems most people are due a refurb anyway so the solution should be free :)
#59 RYN
RYN
  • 489 posts
Posted 08 August 2013 - 04:03 PM
Ok just got chance to measure mine Nitron ntr 395mm So need mine sorting when we no what's going on
#60 Bumblebee
Bumblebee
  • 7,592 posts
Posted 08 August 2013 - 06:25 PM
I've still not got round to checking mine, is there a deadline for this?
