Saab Engine Conversion
Posted 12 August 2013 - 05:56 PM
Posted 12 August 2013 - 06:09 PM
Posted 12 August 2013 - 06:22 PM
Posted 12 August 2013 - 07:28 PM
Posted 12 August 2013 - 08:24 PM
Posted 12 August 2013 - 08:27 PM
Posted 12 August 2013 - 10:46 PM
Your main problem will be the different crank trigger pattern of the Saab engine. Solve that (LSJ ecu or modified crank trigger wheel) and anything is possible...
Posted 13 August 2013 - 07:28 AM
Posted 13 August 2013 - 07:49 AM
Ssymes007, on 12 Aug 2013 - 8:24 PM, said:
Id rather use the saab turbo engine than use a supercharger if the cost works out the same but cant seem to find much info. Having said that i havent checked rosssco's link yet
The cost will not be the same. The supercharger conversion is well known and easy to implement. Fitting a turbo engine to an NA car will have much more work, specifically wiring loom modification, new exhaust. The latter will add £1k to the cost of the conversion.
Posted 13 August 2013 - 09:28 AM
If you want to use the Saab B207 in its native turbo form, OBD Tuner is probably he easiest way to go. I think Peter already has basemaps for this set-up. Not sure what is used for boost control, but an external EBC should work I am told. You could use a Z22SE loom, coilpack etc.
You'd have to use the external trigger wheel and some other parts as mentioned above, and I'm not sure how well the standard manifold and turbo will fit (at least the clam will need chopped, unsure of subframe clearance), then exhaust mods, charge / inter cooling. The rest should be virtually the same as supercharging a Saab engine. If you got a cheap complete Saab (or Z20NET)engine, installed a OBD-T on the ECU, sorted out the chargecooling (intercooler? ), its doesn't have to be anymore expensive thana DIY SC conversion perhaps...
But I totally agree, SC is probably the best approach.
Posted 13 August 2013 - 09:46 AM
Posted 13 August 2013 - 09:57 AM
techieboy, on 13 Aug 2013 - 09:46 AM, said:
Its the additional tuning that the saab engine allows that interests me as i believe that 400hp+ is achievable ?As somebody else said recently, "never build a car that can already be bought", or something along those lines. If you want an I4 2.0 turbo, buy a VXT. Simples.
Posted 13 August 2013 - 10:00 AM
Posted 13 August 2013 - 10:12 AM
techieboy, on 13 Aug 2013 - 10:00 AM, said:
Is there a guy on here called Nev that i heard had a saab conversion done and is running over 400hp but im unsure as to what engine he used?Not on a drop in B207 engine, it's not. I think you're referring to the older generation B204 type engines, which bear no resemblance to the B207/Z22SE/LSJ/L61 engines.
Posted 13 August 2013 - 10:17 AM
Posted 13 August 2013 - 10:51 AM
Posted 13 August 2013 - 11:16 AM
