Are yours brand new mr bargiWow, £250 I offered seems way cheap if that's what they're worth less duty and shipping
Need These In My Life
#21
Posted 13 August 2013 - 09:44 PM
#22
Posted 13 August 2013 - 09:50 PM
BullWithout under tray you would effect dynamics and rear of clam would be floppy
#23
Posted 13 August 2013 - 09:52 PM
We're you old cars metal bodyBullWithout under tray you would effect dynamics and rear of clam would be floppy
I could get some of my old motors to 140 ish with no floor pan. ok shorten it , just leave the rear 12 inch without the pan to drag the heat out without affecting the " dynamics" to much
#24
Posted 13 August 2013 - 09:59 PM
Yes but a mate had a tweaked 3.0 L Scimitar that would knock on without going floppy , I think that's crap.maybe at silly high speeds but most VX s don't see much over 140 ish for long and if old 1970s crap fibreglass cars could cope the VX will. .We're you old cars metal bodyBullWithout under tray you would effect dynamics and rear of clam would be floppy
Edited by ghand, 13 August 2013 - 10:05 PM.
#25
Posted 14 August 2013 - 10:15 AM
Just found this statement from winstar
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]The cooling flow on the NA, with all the important hot bits at the back of the engine, works by flowing up through the NACA ducts over the engine and out of the top vents. Which is why when people space their diffuser they short circuit this and actually incrrease the temps in the exhaust and gearbox area. [/color]
#26
Posted 14 August 2013 - 10:38 AM
#27
Posted 14 August 2013 - 10:44 AM
#28
#29
Posted 14 August 2013 - 10:48 AM
#30
Posted 14 August 2013 - 10:51 AM
Chill...if you want to buy a set of them as per the eBay link:
http://www.ebay.co.u...=item2c6f3be672
I will get a set at the same time, could reduce shipping costs
#31
Posted 14 August 2013 - 10:55 AM
I ran without the floor pan for a few days while waiting for some parts to arrive never noticed any difference. But did not get up to high speeds 60/70 only. I can't see it being a problem. I don't think all the early Lotus had them and plenty of other rear engined plastic car don't bother but they are fitted for a reason I suppose.Just found this statement from winstar
[color=rgb(40,40,40);][font="helvetica;"]The cooling flow on the NA, with all the important hot bits at the back of the engine, works by flowing up through the NACA ducts over the engine and out of the top vents. Which is why when people space their diffuser they short circuit this and actually incrrease the temps in the exhaust and gearbox area. [/color][/font]
#32
Posted 14 August 2013 - 10:57 AM
Any existing cylinder bore wear issues aside, the Wiseco's (because they use a low silicon alloy that expands with heat) need to run larger piston to cylinder clearances than standard (as well as considerably larger ring gaps), to allow for the expansion. Part of the issue I had with my first uprated engine was down to running them with near standard clearances thanks to the engine place not reading the spec sheet (or ignoring it). That and some bore wash meant the rings never bedded-in properly and led to huge oil consumption and death at Silverstone in something like 1500 miles. Expensive lesson. On the bright side, despite some of the big end bearings resembling rizzla papers after being spun and the pistons being more oval than round by the time I'd driven home (well I figured it was fcuked, so might as well see how far I gotA couple of things. I don't thing you can just drop any Wiseco piston in all of them require a rebore I am not sure why?
#33
Posted 14 August 2013 - 11:01 AM
The systems can trap air though I have never had this issue. Your drive is steep, have you got the car hot then with nose up then down bleed the system?
Yes im confident there is no air in the system, as you said i bled it on my drive which very steep, ive also done 2 track days since changing the header tank and think this would of bought any other air out..
#34
Posted 14 August 2013 - 11:04 AM
when are you planning on getting yours
#35
Posted 14 August 2013 - 11:10 AM
jesus one of my rods was that much
wish my engine parts were cheaper
Edited by Thealastair34, 14 August 2013 - 11:10 AM.
#36
Posted 14 August 2013 - 11:19 AM
I have just had a thought please dont shoot me down,
do you thing re introducing the PCV opening would help with cooling, because the engine would be able to breathe better.???
#37
Posted 14 August 2013 - 11:43 AM
My temps have been steady as a rock since my conversion, in fact although the car gets hotter quicker it seems better than as an NA - I can't really understand how your car could be so different to mine - it must be connected some how to the cooling system.
#38
Posted 14 August 2013 - 11:49 AM
Are you running a rich courtenay map or dutch ecu software
#39
Posted 14 August 2013 - 11:50 AM
DId I read somewhere you did not have any ducts in your undertray?
#40
Posted 14 August 2013 - 11:51 AM
They will be back in this weekendDId I read somewhere you did not have any ducts in your undertray?
