Heads just blown up
Need These In My Life
#81
Posted 15 August 2013 - 10:01 AM
#82
Posted 15 August 2013 - 10:06 AM
#83
Posted 15 August 2013 - 10:07 AM
#84
Posted 15 August 2013 - 10:11 AM
#85
Posted 15 August 2013 - 10:19 AM
#86
#87
Posted 15 August 2013 - 10:20 AM
And that was the laymans version...
If you look at my gallery lin beloe, you will see some pics Peter @ OBDT sent me on the additional parts required to run the Saab engine with the Z22SE ECU.
Basically:
External crank trigger wheel and sensor
Modified ignition module and cover plate
Oil cooler connection
Cam cover blank
http://www.vx220.org.../14331-rosssco/
#88
Posted 15 August 2013 - 10:21 AM
5 new engines for £800+vat each. Shall we start a list?
Yes
#89
Posted 15 August 2013 - 10:23 AM
#90
Posted 15 August 2013 - 10:24 AM
#91
That is a good price! I was going to suggest these guys as well, but shipping would be extra.
http://saabpartners....ath=107_122_135
Anyone know the estimated running in time for one of these (or similar) Ecotec engines?
#92
New thread, leave this one for more technical talk
#93
Posted 15 August 2013 - 10:25 AM
#95
Posted 15 August 2013 - 10:35 AM
I think we are going to change crank so we will be using original z22se wiring and no external trigger wheelAnd that was the laymans version...
Basically:
Cam cover blank
#96
Posted 15 August 2013 - 10:39 AM
Basically:
Cam cover blank
Is the Z22SE crank compatible with the B207 rods? Its also heavier than the B207 crank, and possibly, not as strong..? I also read somewhere you have to clearance the block, but I'm maybe thinking of something else...
#97
Posted 15 August 2013 - 10:41 AM
#98
Posted 15 August 2013 - 10:43 AM
Check the specs of the B207E/L pistons. I've just been through the Saab WIS (their version of the EPC) and the E/L pistons are a totally different part number to the 9.5:1 pistons in the B207R. As the E/L runs a low pressure turbo (instead of the higher pressure turbo in the R), they might be higher compression pistons or different alloy.
#99
Posted 15 August 2013 - 10:46 AM
#100
Posted 15 August 2013 - 10:48 AM
Ignore my previous post if you're planning on changing the pistons anyway. I'm doing the exact opposite and moving to a standard B207R bottom end, specifically to get away from nasty cheap'ish Wiseco aftermarket pistons and their drawbacks and return to OEM quality.We up dating the rods and pistons as a minimal
