Need These In My Life
#141
Posted 16 August 2013 - 11:25 AM
#142
Lol She is a vx widow but she still gets servicedI doubt he will need any convincing. It's his wife that needs work me thinks.I thought the purpose of this thread was convincing chill to build a 350+bhp monster?!
#143
Posted 16 August 2013 - 11:26 AM
Yep im up for thatMy insurance is currently out as well, but good call on checking through the pc. It might just be the reader, I have two and one is a lot better than the other. I might have to invite you down in exchange for beer, bacon baps and pizza to help map mine for the WOT part
#144
Posted 16 August 2013 - 04:28 PM
I thought the purpose of this thread was convincing chill to build a 350+bhp monster?!Each to their own, but a bog stock supercharged 2.0 B207 with some std LSJ cams in feels really nice in a VX.
That's easy then; buy a Saab, lift the head, port the exhaust, fit some springs & SC cams and put it all together with a Harrop and a decent exhaust. 350HP is much easier above 7500rpm.
#145
Posted 16 August 2013 - 04:31 PM
Chills wife will be happyThat's easy then; buy a Saab, lift the head, port the exhaust, fit some springs & SC cams and put it all together with a Harrop and a decent exhaust. 350HP is much easier above 7500rpm.
#146
Posted 16 August 2013 - 05:32 PM
Don't forget pistons and rods.That's easy then; buy a Saab, lift the head, port the exhaust, fit some springs & SC cams and put it all together with a Harrop and a decent exhaust. 350HP is much easier above 7500rpm.
#147
Posted 16 August 2013 - 05:45 PM
I think the dutch are going to do some piston stress testing of their own.....
Z22SE = L61
B207 = LSJ
All this destructive testing to spit out those numbers was done with NOS.
http://www.turbovmax...ort Fighter.pdf
So fingers crossed for the harrop on stock b207, with a reasonably pully on, pushing for 330isch with 400nm torque and hope for the best.
Edited by smiley, 16 August 2013 - 06:07 PM.
#148
Posted 16 August 2013 - 06:04 PM
#149
Posted 16 August 2013 - 06:06 PM
Rods are near twice as strong as z22se?
Cool enigine huh
#150
Posted 16 August 2013 - 06:08 PM
#151
Posted 16 August 2013 - 06:46 PM
#152
Posted 16 August 2013 - 06:48 PM
Well, if the US guys can sustain 350-370 whp on their supercharged LSJ's, 330-350BHP should last a while in a light VX. As long as you keep the charge cool, as that will be more of your problem.
#153
Posted 16 August 2013 - 06:50 PM
#154
Posted 16 August 2013 - 06:52 PM
No, B207 has a 23mm wristpin. (and forged rods) The Z22SE a 20mm.
Pistons are the weak link, being silent OEM hypereutectic stuff, but still much thougher build (ringlands) than the Z22SE's. With good tuning (no knock) they should last a while.
#155
Posted 16 August 2013 - 07:32 PM
Are we saying the internals on the B207el are the lsj internals
GM-USA simply took a 2.0 Saab engine, binned the turbo gubbins and bolted the SC stuff on. (ok, some minor tweaks for M8 mani bolts and SC cams.)
Only I cannot find the diference between B207 E/L & R pistons, but lets assume the LSJ used the more expensive R-type pistons.
#156
Posted 16 August 2013 - 08:00 PM
#157
Posted 16 August 2013 - 08:05 PM
A quick google search on most places confirms that E/L/R internals are the same, and only the bolt on stuff differs.
http://www.saabcentr...ead.php?t=17892
#158
Posted 16 August 2013 - 08:10 PM
Edited by CHILL Gone DUTCH, 16 August 2013 - 08:11 PM.
#159
Posted 16 August 2013 - 08:21 PM
Does only say they appear to be the same
I know. A few more sites mentioned the same. Was just one example.
#160
Posted 16 August 2013 - 09:59 PM
Yes I think the el version may use the latter pistons and rods which are similar to the z22se (L61/le5) This is all irrevelant to me because I'm changing mine to a 2.2 crank forged pistons rods With no external trigger.
E/L has same forged rods (and crank) as the R version. There are 2 different B207 piston/ring part types listed, but I'm told that the later engines all got the same R internals.
But that's all irrelevant to you anyway...
