Saab B207 Brand New Engine
b207 saab
756 replies to this topic
#381 Dominique
Dominique
  • 138 posts
Posted 09 October 2013 - 08:02 AM
If this will be your first map from peter Can I have a copy of the base map please We will have to find somewhere to get cams from
  With pleasure (assuming you know how to share this, I haven't a clue) but I will be Harroping so I assume the base map may be different..? Unless the Harrop base map is what you want...?
Not initially I will only be using m62 to start with Until somone comes up with a good modification to keep the IAT down
That's exactly my idea. Standard B207 engine with M62 and ODBtuner.
Some are experimenting with water injection succesfully, which might be a future step. I just don't like the idea of adding an other system to car...
I've been driving with Dutch software for 3 years now and obviously will keep it.
The Z22SE ignition coil has just been modified to fit the B207 rocker cover as the coils are not compatible.
The easier way is to put the Z22SE rocker cover on the new engine, but I prefer the flat looks of the B207 one.
#382 CHILL Gone DUTCH
Posted 09 October 2013 - 08:40 AM
I am changing the engine to 2.2 and changing rods and pistons for any future developments
#383 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 09 October 2013 - 10:51 AM
So you are running it as a regular 2.0-litre B207 then?
And you have an external trigger wheel also - where did you get this from, Hitech? Is there anything else that needs done, save for the ignition coil modifcation already mentioned, to make all this work?
G
#384 robin
robin
  • 3,810 posts
Posted 09 October 2013 - 11:10 AM
Has anyone found where a external trigger can be sourced from yet?
#385 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 09 October 2013 - 11:16 AM
Not as such, someone (maybe me when I find the time) needs to speak to Welshiejon on here. I'm confident that someone will be able to make one if we can't pick one up off the shelf from somewhere.
G
#386 techieboy
Posted 09 October 2013 - 11:36 AM
New flywheel.
#387 Dominique
Dominique
  • 138 posts
Posted 09 October 2013 - 11:37 AM
It'll stay 2.0 ltrs / M62 with a light flywheel to make it happily reving.
I believe the crankpattern and the coils are the only things that should stay Z22SE for the ECU.
The idea in my case is to take the bolted B207 triggerwheel out and replace it with one with the Z22SE pattern.  Unfortunately this triggerwheel has no GM partnumber, so will be home made and has therefore an experimental character. Bear in mind, the cranck shaft has to be taken out of the brandnew engine. new stretch bolts etc... there are easier ways... :glare:
The external triggerwheel from Hitec is on order as a back up plan.
As Techieboy mentioned, the flywheel has a different bolt pattern.
Edited by Dominique, 09 October 2013 - 11:40 AM.
#388 techieboy
Posted 09 October 2013 - 11:39 AM
Graeme, if you get in contact with HiTec, I'd also probably be interested in his trigger wheel and crank sensor bracket as we know he's got the timing on his version sorted.
#389 Tony H
Tony H
    Lotus on Crack
  • 1,729 posts
Posted 09 October 2013 - 12:56 PM
I have just picked my b207 up. :happy: Obviously I will be needing the same adaptations as the rest of you so let me know if we are going to be group buying stuff.
Thanks to Artic and Chill for organising.
Edited by Tony H, 09 October 2013 - 12:59 PM.
#390 smiley
Posted 09 October 2013 - 12:58 PM
I´m also leaving it 2.0 with lighter flywheel, exhaust port flowed and some hitec goodies.
Then the harrop on, and see what happens.
#391 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 09 October 2013 - 01:15 PM
Okay,
Assuming I manage to buy the B207 at the end of the month then I'll make contact and investigate whether we can do some sort of group buy/group deal.
G
#392 techieboy
Posted 09 October 2013 - 01:29 PM
Yeah, I'd like to buy a brand new one but at least I've got one sat here in the garage anyway. In all honesty, the bits will probably end up in the pile of shiny bits that already exists for the LSJ/HPTuners conversion and I'll do nothing with any of them. :wacko:
#393 CHILL Gone DUTCH
Posted 09 October 2013 - 06:45 PM
I have just picked my b207 up. :happy: Obviously I will be needing the same adaptations as the rest of you so let me know if we are going to be group buying stuff.   Thanks to Artic and Chill for organising.
I can't take any credit for organising this stu. ( artic) did the ground work
#394 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 09 October 2013 - 06:49 PM
All donations welcome.
#395 fezzasus
Posted 09 October 2013 - 07:52 PM
If it'll help incentivise you, name a price for the one you have.
#396 vocky
Posted 10 October 2013 - 06:53 PM
a few pics of one of the engines :happy:
valves
pistons
just a reminder to use flat seal spark plugs not the z22se taper plugs
and two of the oilways which need blanking off are circled in red
So will anyone be keeping the servo vacuum pump and connecting it up to the brakes :huh:
#397 CHILL Gone DUTCH
Posted 10 October 2013 - 06:58 PM
How much are the rods and pistons worth, Have you confirmed which type of pistons they are
#398 vocky
Posted 10 October 2013 - 07:00 PM
not removed them yet :P
as for value, the ones in the picture above will probably go to the tip, worthless  :mellow:
#399 vocky
Posted 10 October 2013 - 07:02 PM
double post due to site being a pain yet again :glare:
Edited by vocky, 10 October 2013 - 07:14 PM.
#400 CHILL Gone DUTCH
Posted 10 October 2013 - 07:04 PM
Who's is being done first mr vock
Also tagged with one or more of these keywords: b207, saab
