Saab B207 Brand New Engine
b207 saab
756 replies to this topic
#401 vocky
Posted 10 October 2013 - 07:09 PM
Who's is being done first mr vock
dunno, I bought this one for a little project  :ninja:
#402 CHILL Gone DUTCH
Posted 10 October 2013 - 07:17 PM
#403 CHILL Gone DUTCH
Posted 10 October 2013 - 07:20 PM
Can somone circle the internals of the new engines as I was wondering about valves,
#404 vocky
Posted 11 October 2013 - 06:54 AM
red = SAAB
blue = z22se
#405 Sutol
Sutol
    Well it's nearly a Lotus
  • 8,122 posts
Posted 11 October 2013 - 09:01 AM
!!UPDATE!!
Good condition, working order starter motor £24.
All invoices will have the engine code printed and your name tagged to that engine. This will cover you on Techie's point about DVLA requirments.
That's a very sweet deal.
Any chance on new ones?
Is this an option, getting a new starter motor or go with reconning the existing one - will it fit the 207?
#406 smiley
Posted 11 October 2013 - 09:35 AM
Yes, old ones are fully compliant.
Only reason i asked is that my z22se one has done many miles, and i don´t like putting old stuff into a brand new engine.
#407 Exmantaa
Posted 11 October 2013 - 09:45 AM
Stu don't suppose you found out the answer to techies question did you (no rush to be fair). And smiley I'll be happy with anything between 280 and 300bhp I think. Seems like a potential cost/reliability sweet spot. G
280 HP is easy with the Saab. =>
Standard B207 engine, fit some stock LSJ supercharger cams (or re-time the B207R turbo cams), mount the supercharger kit with a 3.1 pulley and tune the ecu for VXR, #42 or #50 injectors.
I got 282HP with the restrictive cast 2,2 exh. manifold mounted and not fully optimised tune.
 Choose your upgrades from there... :happy:
#408 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 11 October 2013 - 10:17 AM
If this was Facebook I'd like this post very much :wub:
My plan, well the seed planted by Vocky, was for Comp cams also and I already have Tullet 4-1 manifold.
G
#409 vocky
Posted 11 October 2013 - 05:22 PM
the Saab pistons in this engine I'm stripping down are made by MAHLE, not sure if that means anything ?
Exmantaa might know if they are any good :poke:
Edited by vocky, 11 October 2013 - 05:24 PM.
#410 fezzasus
Posted 11 October 2013 - 05:44 PM
MAHLE are a standard OEM supplier, they'll be in 90 % of all standard engines
#411 vocky
Posted 11 October 2013 - 06:59 PM
they don't look that 'special', will get some pics up over the weekend
The little end bearings do look quite fancy, will try and get a pic of them
#412 Bargi
Bargi
  • 4,483 posts
Posted 11 October 2013 - 08:10 PM
So Z22SE valves are good for the same power the Saab pistons will go to, which has been well over 300bhp based on our continental friends...
#413 Speedy4Fun
Speedy4Fun
  • 82 posts
Posted 12 October 2013 - 08:35 AM
Can you check for the casting code inside the piston?
Should be a 5 or 7 digit code consisting of numbers and in the middle a letter.
#414 vocky
Posted 12 October 2013 - 05:13 PM
A1
86L66+
MAHLE
FO71
#415 Speedy4Fun
Speedy4Fun
  • 82 posts
Posted 12 October 2013 - 07:10 PM
A1
86L66+
MAHLE
FO71
And that's from the new Saab B207 engine?
I have a Z20NET (=B207L=LSJ)  piston in front of me with exactly the same codes except for the FO71 which is FO61 for my piston.
Probably means no difference's between the Z20NET,B207L or the B207R pistons :dry:
#416 smiley
Posted 12 October 2013 - 07:24 PM
A1
86L66+
MAHLE
FO71
Are the codes on the oem LSJ pistons known?
#417 Exmantaa
Posted 12 October 2013 - 11:21 PM
A1
86L66+
MAHLE
FO71
from a older post:
In the inside of every MAHLE - Piston you can find a casting number. This number consists out of two numbers, then a letter and again two numbers. From the letter you can find out of what kind the piston is: D... Duotherm piston F... Squeeze-cast piston KB... Ferrotherm piston L... Solid skirt piston P... Forged piston V... Auto-/Hydrothermik piston/ Auto-/Hydrothermatik piston For example: A piston with the casting number 96 P 26 would be a forged piston.
#418 Kieran McC
Kieran McC
  • 3,416 posts
Posted 13 October 2013 - 08:07 AM
This not the easiest of conversions if you have a M32 gear box. :drink:
#419 vocky
Posted 13 October 2013 - 09:16 AM
just ask TTV for an eight bolt z22se M32 flywheel ;)
#420 Kieran McC
Kieran McC
  • 3,416 posts
Posted 13 October 2013 - 10:01 AM
That is what we had to do. Turbo rear wishbone , Clutch conversion .
Also tagged with one or more of these keywords: b207, saab
