Saab B207 Brand New Engine
b207 saab
756 replies to this topic
#721 Rosssco
Rosssco
  • 4,183 posts
Posted 20 January 2018 - 03:22 PM
or just keep the b207 intact and run the trionic 8 ecu
Since most will be used with Superchargers, an LSJ ECU and loom would probably suit a bit better (I dunno anyone on here with this Trionic knowledge)
Or ask peter to offset the 2.0 trigger to match the 2.2
Can he do this  - I thought there had to be some physically different trigger wheel..?
#722 Rosssco
Rosssco
  • 4,183 posts
Posted 20 January 2018 - 03:24 PM
Still tempted by one of these. Sell my existing 2.4 hybrid and go small pulley on a standard B207 engine with some cams.. Hmmm..
#723 CHILL Gone DUTCH
Posted 20 January 2018 - 03:27 PM
I'm sure he could if you gave him the information of how much the signal need to retard or advance the signal
#724 Rosssco
Rosssco
  • 4,183 posts
Posted 20 January 2018 - 03:43 PM
Its not a timing thing though, its that a different trigger pattern is used - 7-1 (Z22SE) vs. 58-2 (B207 and newer GM engines).
#725 CHILL Gone DUTCH
Posted 20 January 2018 - 03:46 PM
maybe not then Always worth a question though must somthing that could be done
#726 TFD
TFD
  • 607 posts
Posted 22 January 2018 - 11:11 AM
  There are no external trigger wheels available to make the 2.0 work with the z22se ECU and I strongly advise that anyone who buys one converts it to a 2.2, using the z22se crank, z22se conrods (steel) and 2.2 pistons (forged).   Or Z22YH pistons and rods, with a z22se crank for NA or ITBs   You should consider these as donor engines, to be fully stripped and the parts used to build a strong engine. I bin the 2.0 parts = pistons, rods, crank and cams
What do you mean with not available and why the advice to convert to 2.2? Whats wrong with the 2.0 + Ex.triggerwheel? Genuine question.
#727 Rosssco
Rosssco
  • 4,183 posts
Posted 22 January 2018 - 11:36 AM
Because VX220 :P
#728 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 22 January 2018 - 08:40 PM
to save you having to find a calculator that equals £714 inc vat, plus delivery
Tempted to get one for the vx, need a gearbox though, and ecu
#729 CHILL Gone DUTCH
Posted 22 January 2018 - 08:48 PM
I thought you had sold up ??
#730 NickB787
NickB787
  • 7,813 posts
Posted 22 January 2018 - 09:19 PM
No got a vx here minus engine,gearbox, ecu, driveshafts, front clam, lights but the rest is ok.
been thinking what to do with it.
#731 The Batman
Posted 23 January 2018 - 03:23 AM
I have a gearbox and a front clam  :)
#732 Exmantaa
Posted 23 January 2018 - 11:21 AM
Nothing wrong with the 2.0 and external trigger, just you can make more power with the 2.2 displacement . (as with a 2.3 or a 2.4liter engine...)
Trionic 8 is beautifull, but no idea if it is now fully cracked.
Stock B207 internals, flowed head, Harrop supercharger plus the LSJ ecu; all still running strong. :happy:
#733 vocky
Posted 23 January 2018 - 11:36 AM
you can get an internal 5+2 trigger wheel from the states to use on the 2.0 crank, so that the z22se ECU works okay. But I would strongly advise fitting some forged pistons and steel rods whilst it's apart, then the engine would be good for 400bhp.
But it would be cheaper to just swap the crank with a z22se and go Wiseco pistons and Eagle steel 2.2 rods
#734 Exmantaa
Posted 23 January 2018 - 02:59 PM
Can you post a link for the internal triggerwheel? As you can also use that as external...
#735 TFD
TFD
  • 607 posts
Posted 26 January 2018 - 09:06 PM
Came home just about a half hour ago from an 11 hour drive from Austria... to find a big pallet in my backyard ;)
#736 TFD
TFD
  • 607 posts
Posted 27 January 2018 - 10:39 PM
Ok... question:
I recieved a new engine:
But it got this stamp on it wich says its an A20NFT engine:
The sticker on the valvecover says "B207".
According to wiki the a20nft is a new version and different then the "oldscool" b207's.
Is there just a wrong sticker on the engine or is it a real a20nft? Head and intake mani looks def like a b207.
A bit confused here.
Edited by TFD, 27 January 2018 - 10:43 PM.
#737 TFD
TFD
  • 607 posts
Posted 27 January 2018 - 10:57 PM
From previous post Articmonkey and Exmanta stated the newest b207r engines are A20NUR coded. Guess mine is some different?
#738 CHILL Gone DUTCH
Posted 28 January 2018 - 12:17 AM
Mine was also a20nft
#739 CHILL Gone DUTCH
Posted 28 January 2018 - 12:22 AM
It believe mine is a b207 E/L There was a discussion about what the differences were But can't remember the answer
#740 TFD
TFD
  • 607 posts
Posted 28 January 2018 - 04:59 AM
Yes the GB stated it were b207e/l engines. Just wonderd how a20nft got on there since the nft is a complete different. Sended neo an email.
Also tagged with one or more of these keywords: b207, saab
    Bing (1)
