Saab B207 Brand New Engine
b207 saab
756 replies to this topic
#741 vocky
Posted 28 January 2018 - 10:06 AM
normally when the a20nft is mentioned it refers to the astra J vxr VVT engine
But from your photos it is a late spec B207 engine
I wonder if you have a GEN 3 block :D
#742 TFD
TFD
  • 607 posts
Posted 28 January 2018 - 10:22 AM
My thoughts (or confusion) exactly.
That would be awesome. 500HP here we come  chinky chinky
Take the head off and see if it's reinforced. Mhh...
#743 vocky
Posted 28 January 2018 - 10:30 AM
If it's a GEN 3 block I'm buying a couple of engines :ninja:
#744 CHILL Gone DUTCH
Posted 28 January 2018 - 11:05 AM
There only Gen 2 400 hp max
#745 vocky
Posted 28 January 2018 - 12:46 PM
if they have the extra webbing on the cylinder bores then they are not GEN 2
#746 CHILL Gone DUTCH
Posted 28 January 2018 - 12:49 PM
What's mine likely to be vocky Can I push it past 400 ??
#747 Exmantaa
Posted 28 January 2018 - 01:49 PM
A "Gen 3" has reinforced cilinder walls and a sandcast block.
This surface finish does not look like sandcast:
Very curious what pistons etc. this A20NFT block has fitted. And what code is stamped into the oil filter housing?
#748 vocky
Posted 28 January 2018 - 03:12 PM
the block in TFD's photos is a GEN 2, the A20NFT vvt engine block is cast different and has no blanking plugs below the exhaust
#749 Rosssco
Rosssco
  • 4,183 posts
Posted 29 January 2018 - 09:19 AM
The 'real' A20NFT also has a different coolant cross-over pipe and thermostat housing to accommodate the K04 turbo gubbins.. I think GM have sticker issues.
#750 smiley
Posted 29 January 2018 - 09:47 AM
Take the head off TFD.
We need to know if Saab bodged their head on an NFT, or if we are looking at sticker creativity.
#751 Rosssco
Rosssco
  • 4,183 posts
Posted 29 January 2018 - 10:03 AM
The 'NFT' and 'NHT' tags are slightly interchangeable in Europe it seems. The NHT is the Gen 2 bottom end (same as B207 really, and the older LNF engine used in the US) but will have different pistons and a lower CR (9.2:1) than the B207, and I don't think its any stronger than the B207.
If you had a borescope, you could eyeball the pistons through the sparkplug hole and see if its fitted with the direct injection pistons. I strongly doubt it will be though, and if it was I'd be sending it back!
#752 TFD
TFD
  • 607 posts
Posted 29 January 2018 - 11:33 AM
Reply from Neo Brothers: Hi there, Thank you for your email, the engines are the same and the different coding is just internal information from Saab. You wont have any issues with the fitment of this engine. ------------- I have a borescoop and will check some numbers on the block this week.
#753 CHILL Gone DUTCH
Posted 29 January 2018 - 01:04 PM
These are the nft pistons that were in my engine
#754 Rosssco
Rosssco
  • 4,183 posts
Posted 29 January 2018 - 02:03 PM
That's just a standard B207 piston. The 'real' A20NFT pistons have a little bowl in the top to aid fuel dispersal from the direct injector: https://www.cobaltss...zpsawjmqxvn.jpg
#755 Rosssco
Rosssco
  • 4,183 posts
Posted 14 February 2018 - 01:53 PM
Might have just bought one too.. :D
For info, they will supply a new OEM belt tensioner for £35.95 + vat
#756 Rosssco
Rosssco
  • 4,183 posts
Posted 17 February 2018 - 04:37 PM
Ordered from Neos Thursday. Delivered Friday.
Stripped on Saturday (with head on the kitchen table for some ex. port tickling - don't say it)
As above, I can confirm the supplied 'A20NFT' engines (mine had the same stickers as TFD) are just B207 engines (Gen 2 blocks / pistons etc.). The ID markings on the oil filter also have 'B207' and 'A20NFT' marked on them.
#757 TFD
TFD
  • 607 posts
Posted 17 February 2018 - 04:43 PM
Nice. I wont have to strip the engine in a hurry now.
Also tagged with one or more of these keywords: b207, saab
