#61
Posted 17 August 2013 - 02:56 PM
#62
Posted 17 August 2013 - 03:10 PM
21k more miles than mine and running on a dodgy map.What's up with my engine, 65k miles Always uses oil Always starts Fully abused
#63
Posted 17 August 2013 - 03:14 PM
I'm not selling anyway i would rather keep it and gave a play with it21k more miles than mine and running on a dodgy map.What's up with my engine, 65k miles Always uses oil Always starts Fully abused
#64
Posted 17 August 2013 - 03:29 PM
#65
Posted 17 August 2013 - 03:38 PM
#66
Posted 17 August 2013 - 03:42 PM
#67
#68
Posted 17 August 2013 - 04:20 PM
No Dutch mate.Need to confirm about shipping though. Is it a French address?
#69
Posted 17 August 2013 - 04:36 PM
#70
Posted 17 August 2013 - 04:39 PM
#71
Posted 18 August 2013 - 10:18 AM
#72
Posted 18 August 2013 - 10:23 AM
#73
Posted 18 August 2013 - 11:33 AM
#74
Posted 18 August 2013 - 03:43 PM
Yeah, B207 needs a few tweaks to fit.
Using the Saab head is already documented in several topics. The oil cooler adapter can be bought or original Saab modded (see my LSJ thread)
You need to use a water thermostat housing of the Z22SE and off course a crank trigger modification for Z22SE ecu.
#75
Posted 18 August 2013 - 04:40 PM
Just adding to this; if you come to Zandvoort next week you can see 2 running B207's yourself; a stock one with M62 and a 300++ Harrop breathing version.
#76
Posted 18 August 2013 - 04:43 PM
these are pretty much all the parts which probably need replacing on a higher mileage z22se engine to make it 'as good as new'
90571925 crank pulley oil seal - £7.58 + vat 90325572 crankshaft rear oil seal - £21.66 + vat 93166701 oil pump - £262.72 + vat 24435052 oil pump gasket - £10.08 + vat 55563405 water pump chain kit - £122.21 + vat 55570337 cam chain kit - £152.10 + vat 90537241 valve stem seals x 16 - £38.08 + vat 9198195 oil cooler adaptor seals x 2 - £6* + vat 93175493 oil filter - £4.93 + vat 12630084 water pump - £54 + vat 90537811 thermostat - £9.02 + vat 9230949 exhaust manifold gasket - £5.71 + vat 90537691 head bolts x 10 - £21.70 + vat 12786262 inlet manifold gasket (head to inlet) - saab B207L or Vectra z20net - £6* + vat 93175913 head gasket - saab B207L or Vectra z20net - £39.02 + vat 12591093 big end bearings - £30* + vat 12591092 main bearings - £50* + vat 9194698 cam followers x 16 - £375.94
spark plugs - £25
rebore - £120 + vat
16 x valve guides - £320 + vat
total : £1937.84
For the brand new saab b207 engine you would require;
NGK BKR7EIX Iridium spark plugs - for Saab /z20net - £25
Depending on whether you use LSJ cams or z22se cams - cam blank £50
Oilway blank - £50
saab head temperature sender blanking plug - £0 = use an old water pump drain plug.
secondhand z22se crank - £50
Plus you get brand new; saab sump, saab head, sodium filled valves, roller rockers, crank pulley,
etc
total : £930 + £269.12 = £1199.12
* = cannot find a price on the net, so 'guesstimate'
parts from the usa required for both engines - exact cost varies;
1 x set of Eagle Rods 1 x Wiseco 8.9:1 Piston kit 1 x pair of SC Comp Cams
So a saving of £738.72, give or take a few quid, if you purchase a brand new saab engine and convert it to a 2.2 stage 3 SC instead of converting a z22se to stage 3 SC
If you wish to keep it a 2.0 then it's a saving of £861.59 plus whatever a set of eagle steel rods and wiseco pistons cost, you would however need to fit some LSJ cams and an external trigger wheel.
Edited by vocky, 18 August 2013 - 05:04 PM.
#77
Posted 18 August 2013 - 04:51 PM
obviously if you want to use a saab head and sump on a z22se rebuild you need to add another £275 to your total, which makes the difference about £1014
Edited by vocky, 18 August 2013 - 05:05 PM.
#78
Posted 18 August 2013 - 05:44 PM
^^ Man math to the finest...
#79
Posted 18 August 2013 - 06:54 PM
#80
Posted 18 August 2013 - 07:22 PM
Does that not create the same piston slap and oil consumption story as the current stage III guys have?
The oem saab rods can do 400, and and the pistons 300 isch.
Only the harrop guys would need to consider different pistons.
Also tagged with one or more of these keywords: b207, saab
General Discussion →
VX220 Discussion →
Oil Dipstick Level With Saab Sump?Started by ee601 , 02 Apr 2017 ![]() |
The Market Place →
Group Buy Room →
Baffled Sump - Guaging InterestStarted by Matthew Bentley Racing Ltd , 14 Dec 2016 ![]() |
The Market Place →
Car Parts For Sale →
B207 Lightweight FlywheelsStarted by Matthew Bentley Racing Ltd , 09 Dec 2014 ![]() |
The Market Place →
Group Buy Room →
Flywheels - B207 And Z22 - InterestStarted by Matthew Bentley Racing Ltd , 04 Feb 2014 ![]() |
Tuning & Modifications →
Projects →
Project 'once'Started by Graeme Lambert , 24 Jan 2014 ![]() |
Bing (1)
