#141
Posted 05 September 2013 - 10:02 PM
#142
Posted 06 September 2013 - 12:22 PM
As a bit of an FYI, and to get it put down in this thread, the info below came from Vocky
"the only parts the saab 2.0 requires over a 2.2 saab is a V6 flywheel from a Vectra (I believe it's the same as the C20LET flywheel) some decent cams (the saab are shite for bhp) and the external trigger wheel.
Other than that both the 2.0 and 2.2 saab require a blanking plate for the exhaust cam auxillary housing and a blanking plate for the oil filter housing. Both are available from Hitech in Germany or I can make them from alloy plate."
So seems to me that the Saab 2.0 option doesn't look that bad?
G
#143
Posted 06 September 2013 - 12:43 PM
If all you want is 300bhp then the 2.0 saab engine can do that with some CompCams LSJ camshafts fitted.
If you want a high power Harrop stage 4 then really you need to convert it to a 2.2 for the extra 'cubic centimetres' + 'torque'
#144
Posted 06 September 2013 - 12:46 PM
Mr vocky, Do you have a place to get comp cams from struggling to find the right ones, Also would it be possible to go for a 2.4 or 2.5 using this saab unit without any extra boring etcIf all you want is 300bhp then the 2.0 saab engine can do that with some CompCams LSJ camshafts fitted. If you want a high power Harrop stage 4 then really you need to convert it to a 2.2 for the extra 'cubic centimetres' + 'torque'
#145
Posted 06 September 2013 - 12:49 PM
You cannot make this a 2.4 or 2.5 without fitting sleeves, which is crazy money. My 2.5 block was £3.3k in parts
#146
Posted 06 September 2013 - 12:50 PM
Wish I never mentioned that one, thanks for the replyYou cannot make this a 2.4 or 2.5 without fitting sleeves, which is crazy money. My 2.5 block was £3.3k in parts
#147
Posted 06 September 2013 - 12:51 PM
Never go round Vocky's house
keep away from him
he will cost you money !!!!!
But he do make a mighty fine engine
#148
Posted 06 September 2013 - 12:54 PM
LSJ cams are a direct fit into the saab head and do not require an additional cam blank
http://shop.zzperfor...mance-Cams.aspx
stage 2 LSJ cams would probably be the same as z22se Blower cams, but Exmantaa may know better
Edited by vocky, 06 September 2013 - 12:56 PM.
#149
Posted 06 September 2013 - 12:56 PM
Thought you said the saab ones were crapLSJ cams are a direct fit into the saab head and do not require an additional cam blank
#150
Posted 06 September 2013 - 12:58 PM
standard saab cams are shite for bhp, Mr Techie tried some Aero cams and lost bhp over standard z22se cams.
CompCams are performance camshafts, their LSJ cams will create more bhp and fit perfectly to the saab head.
#151
Which, in a nutshell, probably describes my situation/thoughts perfectly.
Especially when you consider the harrop guys, on their current 2.2 engines, only (I know, I can't believe I said 'only' as well) seem to be getting around 350ish bhp. Seems like a lot of extra money for that last 50-70bhp.
G
#152
Posted 06 September 2013 - 01:00 PM
G
that is the problem with tuning any engine, the more bhp you want from it, the more it costs
#153
Posted 06 September 2013 - 01:55 PM
G
Yup, and like the stage 2 turbo versus stage 4 turbo it's the law of diminishing returns. Always a sweet spot early on where you get a lot of extra bang for not a lot of buck, past that it's a downwards spiral of bankruptcy and unhappy partners!
G
#154
Posted 06 September 2013 - 02:34 PM
I'm out, need to buy some French doors instead
list of buyers at £960
1 - chill
2 - 2deano5
3 - articmonkey
4 -
5 -
previous list
1. CHILL
2. D3YMO
3. ArticMonkey
4. 2deano5
5. Mango Motorsport
7. alanoo (ship to FR)
Are you in graham
#155
Posted 06 September 2013 - 02:49 PM
[quote name="vocky" post="1591702" timestamp="1377023438"]
1 - chill
2 - 2deano5
3 - articmonkey
4 -
5 -
previous list
1. CHILL
2. D3YMO
3. ArticMonkey
4. 2deano5
5. Mango Motorsport6. Vocky
Are you in graham
I thought I had until, or at least near, the end of the month?
I think I am, but I've still not driven a charged car - though I think that'll be of little real significance to the outcome. At the moment I'm 80% committed, but will need a few weeks to confirm. If I'm properly in I'm properly in, cash waiting.
G
#156
Posted 06 September 2013 - 02:52 PM
#157
Posted 06 September 2013 - 02:56 PM
#158
Posted 06 September 2013 - 04:55 PM
Mr vocky Would this engine be a good replacement to the turbo lads to
z22se turbo, yes
z20let turbo, no
#159
Posted 09 September 2013 - 01:34 PM
G
For a VX/Speedster the ~300HP is really quite sufficient. I have around 282 with my bone stock 2.0 LSJ (= Saab B207) on the stock LSJ cams, a stock 2.2 manifold + 2.5 Tullett backbox and only a 3.15" pulley. And that was on a non-optimised tune...
With a decent 4-1 header, some exh. port work, cams & valvesprings you will have your 300+HP, but it's also about the drive and feel of the revvy 2.0 layout.
On the other hand, a Harrop 2.0 @7700rpm is quite mental... (at least untill the cat melts...
But this engine will also have problems with high IAT's, especially on smaller pulleys. I reached ~80*C on Zandvoort last month that robbed some power, so water injection to the resque.
(I'm really very curious to what temperatures you guys reach on track with your smaller pulleys... )
Edited by Exmantaa, 09 September 2013 - 01:35 PM.
#160
Posted 09 September 2013 - 02:57 PM
To be fair, Rob's harrop destroyed the cheap cat tullet put's in, and it was officially a cat for a vx220 NA setup.
Also tagged with one or more of these keywords: b207, saab
General Discussion →
VX220 Discussion →
Oil Dipstick Level With Saab Sump?Started by ee601 , 02 Apr 2017 ![]() |
The Market Place →
Group Buy Room →
Baffled Sump - Guaging InterestStarted by Matthew Bentley Racing Ltd , 14 Dec 2016 ![]() |
The Market Place →
Car Parts For Sale →
B207 Lightweight FlywheelsStarted by Matthew Bentley Racing Ltd , 09 Dec 2014 ![]() |
The Market Place →
Group Buy Room →
Flywheels - B207 And Z22 - InterestStarted by Matthew Bentley Racing Ltd , 04 Feb 2014 ![]() |
Tuning & Modifications →
Projects →
Project 'once'Started by Graeme Lambert , 24 Jan 2014 ![]() |
Bing (2)
