Fezzasus Heater Mk2.6
112 replies to this topic
#1 fezzasus
Posted 17 August 2013 - 10:45 PM
Final iteration for the winter.
Main changes
- Lower thermal mass of heater matrix allows the heater to respond more quickly when temperature is adjusted
- 600 g weight loss compared to earlier versions
- higher fin density for greater heat transfer
- lower profile to aid ease of fitting
Features over OEM heater
- Increased airflow (measured at 170 % of OEM), for more rapid screen clearing and quieter lower speeds
- Fully sealed construction
- Significant increase in heat output
- Fully power coated and galvanised with stainless steel fixings
- Replaced cable control with electronic, preventing stuck or stiff controls.
- 50 Watt resistors for lower fan speeds prevent resistor burnout leading to loss of low speeds.
- Retains MK2.5 improvements with fully encapsulated electronic control unit and connector on cabin control for installation flexibility.
- Provided with neoprene air ducting to replace aluminium duct (better insulation and durability).
Price
- £320 collected from Oxford
- £335.92 shipped Parcelforce 48h
- For a fitted cost please contact JimmyJamJerusalem directly
Four units are available.
#2 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 18 August 2013 - 12:14 AM
Are you making anymore of theses 2.6 versions.
#3 PHB1969
PHB1969
    Premium Member
  • 946 posts
Posted 18 August 2013 - 04:00 AM
Approx how long does it take to fit one?
#4 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 18 August 2013 - 06:33 AM
Fez..you are like the Pagani of VX heaters! :D
#5 fezzasus
Posted 18 August 2013 - 06:36 AM
For me, about two hours. If you're doing it for the first time half a day to a day.
#6 fezzasus
Posted 18 August 2013 - 08:34 AM
They will all be MK2.6 going forward, however I don't know how many that will be. I have a limited supply of fans and will not be buying more.
#7 phippsy
phippsy
  • 472 posts
Posted 10 September 2013 - 12:06 PM
Hi Just a quick enquiry as to whether these uprated heaters are still available. Winters on its way and im not a big fan of the cold. Kind regards Andrew
#8 fezzasus
Posted 10 September 2013 - 01:01 PM
I'll have a batch ready to post out next week.
#9 Steelic
Steelic
  • 544 posts
Posted 10 September 2013 - 02:34 PM
How is the cold setting for fresh air ib the Summer and do they leak hot air like OEM one?
#10 fezzasus
Posted 10 September 2013 - 03:06 PM
cold is cold, it stops the water from flowing through the radiator rather than using a flap to control the air. They don't leak hot air.
#11 Tony H
Tony H
    Lotus on Crack
  • 1,729 posts
Posted 10 September 2013 - 03:38 PM
Can't wait for mine to come. I could see my nipples through my jumper this morning.
#12 JG
JG
  • 13,612 posts
Posted 10 September 2013 - 03:42 PM
3 hours in the rain in the car yesterday and it was freezing, not with the fez though. I kept making minute changes to the temp dial to be just perfect :D
its almost climate control (an easy upgrade for you do Tom)
#13 fezzasus
Posted 10 September 2013 - 03:53 PM
Well, 50 % climate control. I did think about doing it actually, since the system is a PWM it's just a case of using a thermistor and bias pot in place of the current pot.
#14 Rosssco
Rosssco
  • 4,181 posts
Posted 10 September 2013 - 03:54 PM
You should choose your attire more carefully in future
#15 MrGman
MrGman
  • 735 posts
Posted 10 September 2013 - 04:51 PM
How many of these do you plan on having available over the next few months or so?
#16 fezzasus
Posted 10 September 2013 - 05:02 PM
I've just put an order in for another batch of 20 of the laser cut aluminium brackets, so 20.
#17 ollie2007
ollie2007
    Sir drink a lot
  • 1,308 posts
  • Location:Inside my turbo its a beautiful place you know
  • Interests:Working on the VX ,alcohol, drunk street fighting with Rudy. life doesn't get much better than that
Posted 10 September 2013 - 06:43 PM
Fezz when you have made some more can you PM me please, I love my car but I can cough hotter than the heater works.
#18 Spiderman
Spiderman
  • 54 posts
Posted 12 September 2013 - 07:47 PM
Hi Fezz,
I'm really interested too, for a french VXT  :happy: ! Keep us informed when the batch will be there !
Regards from near Lyon,
Spiderman
#19 fezzasus
Posted 12 September 2013 - 07:50 PM
Hi Fezz,
Spiderman
As I said in the PM, the LHD model is different but there is one available already.
Regards, Tom
#20 Cookies220
Cookies220
  • 2,721 posts
Posted 15 September 2013 - 07:29 AM
Hi Tom.
I'm interested in one of these too. Happy to collect thumbsup
