Definitely different then. Just look at the fat end.
Cv Boots
#41
Posted 22 August 2013 - 06:55 PM
#42
Posted 22 August 2013 - 07:13 PM
*snigger*Definitely different then. Just look at the fat end.
#43
Posted 23 August 2013 - 07:54 AM
I get the same response from the missus.
#44
Posted 23 August 2013 - 10:42 AM
Cracking!
3 pages and we are no nearer to CV gaiters that fit, but we're richer to the tune of a couple of fat-greasy nob innuendos.
#45
Posted 23 August 2013 - 10:48 AM
Sure we are. The same as we were 4 years ago, if somebody wants to give it a try
#46
Posted 23 August 2013 - 11:02 AM
I will visit the Honda/Kia showroom this weekend... see what transpires.
Quote I from your thread of many years ago:
Dont know if its any help but had a look on our parts system this morning... 9197858 is the GM number - not the same as any other GM boot kit. Aftermarket wise you will need a Quinton Hazell part number QJB1033 or equivalent. If it helps its also the same as a Honda NSX (42017-SL0-000) or a Kia Sedona (0 K55 22 2540). Sadly we dont keep them in stock.... If you are after a universal one the sizes needed are 25mm shaft size, 87mm joint size with an overall length of 96mm.
I wonder if Techie will still be as grumpy 4 years from now?.... hmmmm..
Good luck with your search! Kevin
#47
Posted 23 August 2013 - 11:05 AM
#48
Posted 23 August 2013 - 11:07 AM
P.S.
#49
Posted 23 August 2013 - 11:12 AM
i had a "Honda NSX" fitted to my old black one.. it lasted longer then the car
#50
Posted 23 August 2013 - 12:31 PM
I have spent the time sizing up the boots and have non-OE alternatives that fit really well. The OE outer is hard plastic and fails very quickly on the race car so I use the rubber boots... Much better IMHO. If people want some I can get some in stock?
#51
Posted 23 August 2013 - 12:35 PM
#52
Posted 23 August 2013 - 10:04 PM
yes, inners please.
#53
Posted 23 August 2013 - 10:07 PM
#54
Posted 24 August 2013 - 10:52 AM
Is that the same cv for both sides?a quick google reveals the astra GSI z20let inner cv gaitor part number is [color=rgb(51,51,51);][font="Verdana;"]9201993[/color][/font]
http://www.ebay.co.u...3-/121016443956
yes, the vx220 uses the same cv joint both sides, the astra only on one side as it has equal length driveshafts so uses different inner cv's
#55
Posted 24 August 2013 - 11:47 AM
I'm in the same boat.....why isn't anybody considering the Astra drive shafts suggested by Smiley?!?
People think the dutch guy is lying through his teeth, and wants to kill everybody.
I went to collect a supposed Astra shaft last night, http://www.ebay.co.u...984.m1423.l2649 to save you clicking through, described as Astra H CDTi near side. It bore passing resemblance, but the inner splines were a different pitch (?) and the oil scroll ran in the opposite direction.
Was it not as described?
My current shaft has gaitors supplied by Liam, they appear to be good.
#56
Posted 24 August 2013 - 11:54 AM
why would a 6 speed M32 astra H share it's cv joints with a 5 speed F23
astra G gsi, z20let, F23 passenger driveshaft
Edited by vocky, 24 August 2013 - 11:55 AM.
#57
Posted 24 August 2013 - 02:01 PM
Yes, that is what i have running for exactly a year now.
Let me verify with the germans for peace of mind.
#58
Posted 24 August 2013 - 03:15 PM
The partnumber 13124675 for the astra H 1.7 cdti mark 5 shaft is listed to be used on an F23.
Edited by smiley, 24 August 2013 - 03:15 PM.
#59
Posted 24 August 2013 - 03:20 PM
This shaft has been used by the germans since 2010 now.
Astra H 1.7 cdti mark 5 100bhp
Engine types Z17DTH and Z17DTR
Partnumbers 13124675 and 374543
I see where you're coming from that they are not 100% identical.
Maybe vocky's is.
Here's a high res of the stra shaft inner side.
If someone has a high res version of the vx one?
Edited by smiley, 24 August 2013 - 03:21 PM.
#60
Posted 24 August 2013 - 03:34 PM
But wouldn't they be using the astra H shaft for the M32 conversion
