Machining Block For Z20Leh Oil Squirters
z20leh oil squirters block z20let
No replies to this topic
#1 cnrandall
cnrandall
  • 943 posts
Posted 25 August 2013 - 08:56 AM
My engine was rebuilt a couple of weeks back and I needed to go back to the original Z20LER block, which is basically a Z20LET.  This block doesn't have the oil squirters so I needed to upgrade it but wanted to retain the OE style jets as opposed to drilling through the main bearing journals.  With the OE fitment you get a better aim on the base of the piston and also the OE parts contain a small oil pressure valve so they shut themselves down to retain oil pressure at low RPM.
Pics of the mods are here https://www.facebook...pe=3&uploaded=3
If anyone wants this done I can do it for £250+VAT + the squirters (haven't priced these up from Vauxhall yet).
Also tagged with one or more of these keywords: z20leh, oil squirters, block, z20let
