Wiring Led Rear Lights (Oem)
Posted 25 August 2013 - 11:25 AM
Here are the results and current plan:
Create a lovely little circuit board to fit in this gap, solder in some LED's and boosh!
Here is the layout I'd like it to have when finished, so it utilises the reflectors and gives more light on the rear end.
There are a few problems with this, I don't have enough red lenses, so I'm not sure how it would take to paint, if it looks crap I'll have to go down another avenue.
They technically won't be road legal, but that's the same with a lot of things...
Any thoughts? Improvements?
Posted 25 August 2013 - 11:34 AM
The standard rear lights look great as they are IMO. Especially the tail lights.
Posted 25 August 2013 - 11:43 AM
Posted 25 August 2013 - 12:16 PM
They will hardly look any different, a very slight change in lens colour, but I'd be surprised if anyone noticed without being told!The standard rear lights look great as they are IMO. Especially the tail lights.
Position aren't set yet, and the good thing is all the lenses are the same size so the circuit boards are the same and they're easy to re-arrangeQuite like the idea but I think you should swap the tail lights with the indicators position, I seem to recall something about having the main rear light markers needing to be located at the outermost points of the vehicle? I may be wrong but it's one more technicality to bare in mind.
That's the main reason for switching it about a bit as well, ideally I'm going to have the tail light running at a slightly lower brightness than the brake light as well.The main benefit of your lense shuffling as I see it is acquiring a separate dedicated brake light, I never like the way on any vehicle where the tail lights simply get a bit brighter.
I agree it's a fair bit of work, replacement LED bulbs won't look half as good though. Elise rear lamp units would look cool, but that even more work and a lot of moulding changes!Other than that it seems a lot of work when the overall look will not have changed much and you could of just put in regular LED replacement bulbs. When I eventually get hold of a rear cluster I intend moulding in LED ring units similar to the Elise.
Posted 25 August 2013 - 03:08 PM
Will need to stick on some reflectors at MOT time for it to pass..
Posted 26 August 2013 - 08:46 AM
I've got a red ill swap you for a clear if that helps?There are a few problems with this, I don't have enough red lenses, so I'm not sure how it would take to paint, if it looks crap I'll have to go down another avenue.
Posted 26 August 2013 - 12:34 PM
I´ve done the same thing with a full set of white lenses.
Posted 26 August 2013 - 12:41 PM
here some pics:
On the first pic the RH indicator (instead of the reflector) fell off on the inside diue to the glueing was not really good.
changed the glue and since then working w/o problems.
Posted 26 August 2013 - 04:08 PM
Posted 26 August 2013 - 06:25 PM
Posted 26 August 2013 - 10:57 PM
What LEDs are you considering?
I'm going to try a few different combinations and see which work out best, I should have enough ultra bright standard 5mm LED's in work to do a set, I'm 99% sure they will be bright enough, there's probably going to be getting on for approx 100 LED's per lamp.
I also want to do a few 10mm versions, purely to see which one turns out better.
I also want to try coloured LED's behind clear lenses, coloured LED's behind coloured lenses and white LED's behind coloured lenses.
Basically it's all just trial and error at the moment!
Posted 26 August 2013 - 11:02 PM
GF ORCE8, did you source the lens from another car/shop?
Posted 27 August 2013 - 06:33 AM
Did all the job based on used VX/Speedster lamps.
Just used LED bulbs.
Have also separated the tail and brake lights, because the "2-wire" led bulbs have hardly any difference in brightness between normal light and brake.
Have some pics how I´ve done it will upload later on.
Just a note! Clam need additional hole for the indicator instead of reflector because of wiring and bulb fixation
Posted 27 August 2013 - 05:18 PM
Plcc4 smd leds are what you want. None of this thru hole shite.I'm going to try a few different combinations and see which work out best, I should have enough ultra bright standard 5mm LED's in work to do a set, I'm 99% sure they will be bright enough, there's probably going to be getting on for approx 100 LED's per lamp. I also want to do a few 10mm versions, purely to see which one turns out better. I also want to try coloured LED's behind clear lenses, coloured LED's behind coloured lenses and white LED's behind coloured lenses. Basically it's all just trial and error at the moment!What LEDs are you considering?
Posted 27 August 2013 - 09:12 PM
Posted 27 August 2013 - 09:17 PM
Posted 27 August 2013 - 09:32 PM
Posted 27 August 2013 - 09:49 PM
Posted 08 April 2018 - 04:52 PM
Was just reading this topic, and wondering if you know where can I get "OEM like" clear lenses? I am struggling to find them. Many Thanks.
