Non Starter...
#181
Posted 04 September 2013 - 10:02 AM
#182
Posted 04 September 2013 - 10:58 AM
Thanks Nick, yep i'm thoroughly fed up with it at the moment. I don't know why, but I was under some sort of delusion that i'd just swap it over and it would be OK. I should have known better!
Hopefully will get the compression test soon to get the readings, confirm what we already know, and then contact the suppliers again and see what they are going to do about it.
Ali, have you contacted them at all yet?
#183
Posted 04 September 2013 - 11:04 AM
Yes, they want to speak to the mechanic who fitted the engine to rule everything out before authorising any warranty repairs or replacement. Which is why I need to get the compression test done, so that a mechanic can call them with the readings and argue the toss about getting it replaced.
#184
Posted 04 September 2013 - 11:06 AM
Gotcha. Hope you get it all sorted
Get Brum out and about again!
#185
Posted 04 September 2013 - 07:18 PM
#186
Posted 04 September 2013 - 07:24 PM
#187
Posted 04 September 2013 - 07:26 PM
#188
Posted 04 September 2013 - 07:30 PM
#189
#190
Posted 04 September 2013 - 07:33 PM
Edited by Nelly Vx, 04 September 2013 - 07:41 PM.
#191
Posted 04 September 2013 - 07:38 PM
so sorry
#192
Posted 04 September 2013 - 07:44 PM
are you sure the crank is actually turning ali?
#193
Posted 04 September 2013 - 07:45 PM
#194
Posted 04 September 2013 - 08:08 PM
#195
Posted 04 September 2013 - 08:10 PM
sounds like your starter isn't even coming into contact with the flywheel....
I've turned my engine over many times without spark plugs in (to get oil flowing), and its still a lot more "resistance" than that
edit: does the aux belt/pulley turn when you're cranking like that?
Can you see the crank moving As above I'm not convinced the starter is turning anything
bump bump
#196
Posted 04 September 2013 - 08:25 PM
that's what they sound like when the chain has snapped
#197
Posted 04 September 2013 - 08:26 PM
#198
Posted 04 September 2013 - 08:28 PM
#199
Posted 04 September 2013 - 08:30 PM
#200
Posted 04 September 2013 - 10:39 PM
So your old engine may still be ok ?
Good luck with the local garage, hope they can sort it,
