Deffo got sparks?
Get a code reader on it.
Posted 01 September 2013 - 05:27 PM
Deffo got sparks?
Posted 01 September 2013 - 05:28 PM
Does the throttle do its strange boot sequence?
If not check the blue plug (of loom of doom infamy) is pushed home fully.
Posted 01 September 2013 - 05:45 PM
All relays in boot properly connected?
Posted 01 September 2013 - 05:50 PM
Posted 01 September 2013 - 05:51 PM
Posted 01 September 2013 - 05:52 PM
Posted 01 September 2013 - 05:53 PM
have you checked for any eml codes ?
also might be worth pulling fuse 8 for 10 minutes to reset the ecu
Also have you fitted the brown and grey relays in the correct holders (in the boot), plus no wires hanging out the relay bases ?
Edited by vocky, 01 September 2013 - 05:56 PM.
Posted 01 September 2013 - 06:07 PM
Defo got spark. Boot sequence? I turn the ignition on and everything whirrs up as normal what else am I listening for?
Look in the throttle and turn the key. It fully shuts, opens a bit and generally faffs on before its ready to start.
Posted 01 September 2013 - 06:09 PM
Posted 01 September 2013 - 06:12 PM
Edited by christhegasman, 01 September 2013 - 06:18 PM.
Posted 01 September 2013 - 07:05 PM
I give up.
We checked all the connectors again and cleaned them up, stack is showing normal temps now.
We tried to jump start it, no joy.
When the alarm goes off, the ECU buzzes. Is that normal?
All the earth points are fine we think.
Fuel is getting to the injectors, we checked the plugs all spark ok and have fuel.
we removed fuse 8 for a while, didn't help.
checked all the relays, they are all seated properly (not actually removed any of them anyway, but checked just in case).
I even tried talking nicely to it, pep talk didn't work.
The clutch isn't right, but that's a different thread/story and wouldn't stop it from starting. It doesn't seem to disengage properly
stupid plastic pile of sh*t, i hate it today.
Posted 01 September 2013 - 07:22 PM
Edited by G-Bob, 01 September 2013 - 07:23 PM.
Posted 01 September 2013 - 07:24 PM
Posted 01 September 2013 - 07:28 PM
I reckon its off the new engine and its not talking to the immobiliser. Hence the questions above, because that sounds like the immobiliser kicking in.DAFT QUESTION ALERT: Is the ECU off your old engine?
Posted 01 September 2013 - 07:30 PM
Have you tried this?
Edited by XXX, 01 September 2013 - 07:31 PM.
Posted 01 September 2013 - 07:32 PM
Posted 01 September 2013 - 07:46 PM
