Non Starter...
382 replies to this topic
#61 siztenboots
  • 26,613 posts
Posted 02 September 2013 - 07:41 AM
when its trying to turn over , do you see the rpm counter move?
#62 AliM
AliM
    insert humour here
  • 9,146 posts
Posted 02 September 2013 - 07:54 AM
Hi Steve,  Didn't get a new coil pack, it was just the block.  The rev counter doesn't move when it's trying to start.  If it was moving, what would that indicate?
#63 vocky
Posted 02 September 2013 - 07:58 AM
you should check the following, in no specific order;
blue and black plugs behind the coolant tank - spray some contact cleaner on them
MAP sensor
throttle body plug
ecu plugs
remove injector rail and using cardboard ensure you really have fuel going into the engine (how 2 mentioned earlier in this thread)
eml codes via opcom or a code reader
there is a small black capacitor near the coilpack, ensure the single black wire is not damaged and shorting out on the cylinder head - this will stop it running.
crank sensor plug is connected - use a mirror unless you want to pull the inlet manifold off .....
cam timing is correct - get piston 1 or 4 to tdc and check chain sprockets position http://www.z22se.co....81/#post-125869
#64 AliM
AliM
    insert humour here
  • 9,146 posts
Posted 02 September 2013 - 08:04 AM
Thanks Neil, will have another look this evening/tomorrow and check things off as I go.
#65 FLD
Posted 02 September 2013 - 08:07 AM
Ali, if you want my op-com lead I'll be over bumcorn way tonight.  Fly out at stoopid o'clock in the morning.  I can also bring a spare coil pack if it helps?
#66 siztenboots
  • 26,613 posts
Posted 02 September 2013 - 08:14 AM
don't know if this will help you
#67 AliM
AliM
    insert humour here
  • 9,146 posts
Posted 02 September 2013 - 08:16 AM
Cheers for the offer Matt, I can't get to you to pick it up unfortunately, my current mode of transport is the bus.  I think JT has one, and a chap who lives by me has said he can send someone round with one!
#68 FLD
Posted 02 September 2013 - 08:28 AM
I'll keep my fingers crossed for good news when I get back.
#69 vocky
Posted 02 September 2013 - 08:43 AM
[wrong engine loom article]
hopefully they retained the entire vx220 engine loom :unsure:
#70 G-Bob
G-Bob
    Embarrassing VX's in an MX5
  • 8,256 posts
Posted 02 September 2013 - 09:00 AM
Stuwy had to change the ECU, ring, and key transponders.
Yup, that was what I had to do with mine when it wouldn't start,  The symptoms are exactly the same and that's why I asked Ali to do the procedure above.  It will quickly tell you if the car is cutting fuel for the immobiliser.
#71 AliM
AliM
    insert humour here
  • 9,146 posts
Posted 02 September 2013 - 09:06 AM
Yep, there was no trickery with the looms, we just left everything as it was.
#72 JohnTurbo
JohnTurbo
    SuperScruff
  • 3,635 posts
  • Interests:Performance cars!
Posted 02 September 2013 - 09:52 AM
Above is the knock sensor as stated. Actually I wasnt very sure about how the cap by the coilpack was attached just as I was leaving, so definitely look at that. I wiggled it and it was loose. Ali is there a crank position sensor fitted to your old engine?
#73 AliM
AliM
    insert humour here
  • 9,146 posts
Posted 02 September 2013 - 10:42 AM
Not that I can see, if it's located under the inlet manifold then it would be on the same side of the engine as that image i've posted up?
Edited by AliM, 02 September 2013 - 10:50 AM.
#74 AliM
AliM
    insert humour here
  • 9,146 posts
Posted 02 September 2013 - 10:58 AM
Here's what's left of the old engine, just in case someone can spot anything!
#75 JohnTurbo
JohnTurbo
    SuperScruff
  • 3,635 posts
Posted 02 September 2013 - 11:34 AM
Crank sensor fitted it looks like. I was pretty sure we didn't swap it.
It is possible (but unlikely) the one on the new engine is duff.
It wouldn't be top of my list.
#76 Bargi
Bargi
  • 4,483 posts
Posted 02 September 2013 - 12:05 PM
apologies if checked, but it's def getting fuel pressure and pump running, haven't inadvertently knocked the fuel cutoff?
#77 AliM
AliM
    insert humour here
  • 9,146 posts
Posted 02 September 2013 - 12:11 PM
Yep checked that thumbsup
#78 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 02 September 2013 - 12:50 PM
hmmmm
the reason mine would not start is because I did not have a matching set of  ecu and transponder + chip. If all yours are still the same I would be pretty quick to rule that out..
The car can't forget chips with the battery disconnected..
I'm not much help Ali other then saying I hope it get sorted :borg:
Have you spoken to the people you bought the engine from and told them it wont start?
Have you got a multi meter to see if everything is getting power like it should?
#79 simonlpearce
simonlpearce
  • 933 posts
Posted 02 September 2013 - 01:33 PM
Not saying your wrong, but mine was sat with no battery for a couple of years with no power going to it and when we came round to putting it back on the road it had to get trailered to Vauxhall for them to re-program it all. As per the OP it would crank but not fire.
#80 vocky
Posted 02 September 2013 - 01:36 PM
I have just got back from another non-starting vx220 (also after an engine swap), the crank sensor wasn't plugged in :mellow:
same symptoms as Ali's, fuel pressure etc, just not starting, NO ecu codes either , once the crank sensor was plugged in it started first press of the button
Edited by vocky, 02 September 2013 - 01:38 PM.
