Non Starter...
382 replies to this topic
#101 vocky
Posted 02 September 2013 - 06:56 PM
best ask the engine supplier for your money back :(
easiest way to prove chain has jumped is to check the cam chain timing marks I mentioned about in post 63 in this thread.
Edited by vocky, 02 September 2013 - 06:58 PM.
#102 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    motorsport especially BTCC
    rugby
    eating out
    keeping fit
Posted 02 September 2013 - 07:01 PM
Name and shame please alli
#103 AliM
AliM
    insert humour here
  • 9,146 posts
Posted 02 September 2013 - 07:07 PM
I'm going to call them tomorrow first to see what the options are. my mate reckons if we give it a tow it might get going if the oil pressure gets up. He said if it's been left on its side then the oil will have drained off the valves. Worth a go before ripping it out again :S
#104 vocky
Posted 02 September 2013 - 07:10 PM
do not tow start a z22se, the chain will jump.
The chain tensioner needs oil pressure to work correctly, PLEASE check the cam timing, it only takes 20 minutes and will prove if the chain has slipped.
#105 AliM
AliM
    insert humour here
  • 9,146 posts
Posted 02 September 2013 - 07:12 PM
Ok will check it tomorrow, cheers.
#106 Kieran McC
Kieran McC
  • 3,416 posts
Sold my engine Ali sorry I cant help
#107 vocky
Posted 02 September 2013 - 07:14 PM
remove coilpack
remove cam cover
remove spark plug from piston number 1
using a very long screwdriver inserted into plug hole, crank engine over with a 21mm spanner on the crank pulley bolt until TDC is reached
check the cam sprockets position with the picture below
#108 vocky
Posted 02 September 2013 - 07:17 PM
the chain coloured links will probably not align, it's the position of the cam sprockets which is important, the exhaust (on the left) and inlet (on the right)should be roughly at the exast position as the pictures
#109 AliM
AliM
    insert humour here
  • 9,146 posts
Posted 02 September 2013 - 07:21 PM
If I open the engine up the supplier might not take it back?
#110 vocky
Posted 02 September 2013 - 07:40 PM
compression test is the only option then, you should have about 11-13 Bar on a good engine
don't forget to open the throttle body for this test, keep foot to floor or jam it open
TIS http://www.speedster...sure, Check.pdf
Edited by vocky, 02 September 2013 - 07:43 PM.
#111 AliM
AliM
    insert humour here
  • 9,146 posts
Posted 02 September 2013 - 07:47 PM
I'm stressing now that I'm going to end up with 2 useless engines and no money! If the compression test doesn't show the right/similar pressures what are my options?
#112 CHILL Gone DUTCH
Posted 02 September 2013 - 07:51 PM
Calm down Ali Don't panic yet lets just do the compression test and take it from there,
#113 Kieran McC
Kieran McC
  • 3,416 posts
Posted 02 September 2013 - 07:54 PM
Ali did they give you any type of warranty with it or was sold as seen ?
#114 AliM
AliM
    insert humour here
  • 9,146 posts
Posted 02 September 2013 - 07:56 PM
90 days, am going to call them tomorrow but I would imagine the warranty is void if I open the engine casing. They've put little blobs of paint over the bolts etc so will be able to tell.
#115 Kieran McC
Kieran McC
  • 3,416 posts
Posted 02 September 2013 - 08:00 PM
Ali just do the compression test get the results if its not ok. take it back , I know its a pain taking it back out but better that than getting a dud.
#116 XXX
XXX
    Invisible ex-VX owner
  • 4,471 posts
Posted 02 September 2013 - 08:01 PM
I presume you have a warranty on the new engine? Then I am sure if you get a mechanics report and/or evidence of major fault than you get a refund???
Hope it is nothing serious...... thumbsup
#117 JohnTurbo
JohnTurbo
    SuperScruff
  • 3,635 posts
  • Interests:Performance cars!
Posted 02 September 2013 - 08:33 PM
Fwiw I agree with you guys, if it makes good compression it can be worked with. I spent much of my youth in that scrapyard pulling things apart for my fiat pandas. Recogniced the initials on the engine. They were always fair. Also they have gone to extraordinary lengths marking the thing, you simply wouldnt do that and then be funny about a return.
#118 Ormes
Ormes
  • 4,612 posts
Posted 02 September 2013 - 08:40 PM
Jeez sorry to hear of your problems Ali :(
#119 turbobob
turbobob
    2/3rds of a Queen
  • 13,833 posts
    Photography
    CARS!!
    Travelling
Posted 02 September 2013 - 08:54 PM
Ali. Panic ye not. You have the law on your side as the buyer and a massive wealth of knowledge and help that is. Org. This is something you will get sorted :)
#120 Pidgeon
Pidgeon
  • 5,254 posts
Posted 03 September 2013 - 09:11 AM
It's not the crank sensor :( I have a mechanic with me who thinks there's valves stuck somewhere, as there is back pressure in the inlet manifold.
I've re-read twice and we've jumped immediately to 'kackered engine'.  We're a long way from that conclusion yet.  Persevere!  Engine swaps are never straightforward.
