Non Starter...
#141
Posted 03 September 2013 - 04:18 PM
#142
#143
Posted 03 September 2013 - 04:19 PM
sounds like your starter isn't even coming into contact with the flywheel....
I've turned my engine over many times without spark plugs in (to get oil flowing), and its still a lot more "resistance" than that
edit: does the aux belt/pulley turn when you're cranking like that?
Edited by rik, 03 September 2013 - 04:21 PM.
#144
Posted 03 September 2013 - 04:26 PM
#145
#146
Posted 03 September 2013 - 04:27 PM
#147
Posted 03 September 2013 - 04:39 PM
That sounds really poorly
#148
Posted 03 September 2013 - 04:43 PM
Have the supplier you bought the engine from got any more?
#149
Posted 03 September 2013 - 04:48 PM
#150
Posted 03 September 2013 - 04:49 PM
#151
Posted 03 September 2013 - 04:52 PM
Yes spot onIt's turning over quicker because of the lack of compression ......
#152
Posted 03 September 2013 - 04:57 PM
I've spoken to the supplier this morning, they'd like to speak to the mechanic who fitted the engine :S in order to authorise any warranty repairs.
repairs would be to replace any bent valve and valve guide, the valve guides always crack when the valves bend. You cannot see the tiny cracks until it's been washed in a hot engine wash machine.
Also if the pistons have 'dinks' then the pistons might need replacing too, depends at what rpm the chain jumped at.
Add a head gasket and head bolts - £45 and £25, plus new timing chains - the reason they jump is they are stretched and worn. Some people don't see the point in replacing them
#153
Posted 03 September 2013 - 05:07 PM
Edited by christhegasman, 03 September 2013 - 05:11 PM.
#154
Posted 03 September 2013 - 05:08 PM
I am not mecahnically minded at all, far from it, so cannot offer any proper techical advice. However, I had a breakdown years ago and had similar sounding problem. RAC man said lack of compression was problem and squirted a tiny bit of oil down each cylinder and this did the trick - engine fired up and all hunky dorey.
Is this worth trying? (please don't so on my suggestion!)
#155
Posted 03 September 2013 - 05:16 PM
#156
Posted 03 September 2013 - 05:19 PM
#157
Posted 03 September 2013 - 05:20 PM
Edited by Claws, 03 September 2013 - 05:22 PM.
#158
Posted 03 September 2013 - 05:21 PM
#159
Posted 03 September 2013 - 05:44 PM
I wouldn't want a other engine from them, Name and shame ali
I wouldn't go that far just yet. They have given her a warranty so it's not in their interest so sell knackered engines.
Ali - if you need anything just shout.
#160
Posted 03 September 2013 - 05:47 PM
So why have they told her that it was a runner when it clearly wasent You have more patience than me Duncan I would be playing fcuk if I had changed a broken engine for a fcuked engineI wouldn't go that far just yet. They have given her a warranty so it's not in their interest so sell knackered engines. Ali - if you need anything just shout.I wouldn't want a other engine from them, Name and shame ali
