Does anyone have a solution for this?
This picture explains the problem:
Best regards
Stephan
Posted 07 September 2013 - 04:45 PM
Posted 07 September 2013 - 04:49 PM
Posted 07 September 2013 - 05:01 PM
The temptation is to twist the conductors to make it neat, this is not advisable. The only way I know of is to strip the conductors all to the exact same length, pull all of the cables together with a cable tie, unscrew the clamp so all the conductors will fit in, make sure they are nice and straight then put them in. Do up the connector a bit at a time making sure all of the conductors stay within the curved part of the clamp. Cut the cable tie off.
Posted 07 September 2013 - 05:07 PM
Posted 07 September 2013 - 05:32 PM
So long as the multiway block is rated to cope with the full system current (about 40 amperes I would imagine, aircraft are more my area of expertise so I'm guessing a bit here) this could be a viable solution. It is always a good idea to avoid introducing extra connections if possible.
Posted 07 September 2013 - 05:36 PM
Posted 07 September 2013 - 05:40 PM
Edited by -Dab-of-Oppo-, 07 September 2013 - 05:50 PM.
Posted 07 September 2013 - 05:42 PM
Posted 07 September 2013 - 05:43 PM
Posted 07 September 2013 - 05:44 PM
I would terminate them into a multiway block and then run a single fat cable to the clamp.
Posted 07 September 2013 - 05:58 PM
They would be best soldered in to a large Lug and bolted to the quick release clamp.
Posted 07 September 2013 - 06:04 PM
I would try soldering 1 at a time with a minimum amount of solder? Catch's all the fraying strands.
Posted 07 September 2013 - 07:25 PM
Posted 07 September 2013 - 07:48 PM
Crimped eyelets. Avoid trying to solder, it'll just drag the heat down the cable and eat the sheath up. Proper crimping tool of course, not a set of pliers/wire cutters!!
Posted 07 September 2013 - 10:42 PM
Truth be told I don't like the look of those battery terminals, they look a bit flimsy. I'd go for something like this, cheap, simple, proven and effective:
http://www.ebay.co.u...=item257407c12f
It will be difficult to make all those cables fit into the clamp of the terminal you have chosen but here goes.
Twist cables together -bad idea in areas of high vibration
Solder - bad idea with a clamped termnal
Crimped eyelet - not compatible with a clamped terminal, terminal posts are much beefier than the clamp bolts on your terminal
Multiway block - all you will be doing is split the 5 cables up just to reintegrate them into one big cable. The CSA of the big cable must be equal to or greater than the sum of your 5 small cables so I can't see what you gain from doing this.
Tightly loom the 5 cables together with a cable tie (tape will do) at the point where the insulation meets the bare conductors, this will effectively give you one big cable. Ensure the conductors are all the same length, insert into the clamp ensuring about 2mm pokes out the other side, do clamp up. In my original post I said to remove the cable tie, this is because you need to do a tug test on each individual cable to ensure they are all seated correctly. It may be a good idea to stick a few cable ties on the loom just to tidy things up after. If the conductors don't fit into the clamp then the terminal is not fit for purpose.
Failing that.......................glue!
Posted 07 September 2013 - 11:07 PM
Posted 08 September 2013 - 07:47 AM
Aside from how to attach the cables, I really like the idea of those connectors. Much neater and easier
Just seen them on flebay for a fiver. My only concern is whether the flip up part would foul on the raised section of the battery.
Edited by Cookies220, 08 September 2013 - 07:56 AM.
Posted 08 September 2013 - 07:50 AM
Posted 08 September 2013 - 08:16 AM
FFS , twist them together and clamp them, only been doing it for 40 fcuking years
in industrial situations on vehicle drawing a lot more current thank a VX. It's not a bloody space shuttle.
and will be fine for ever twisted together. Soldering or crimping the things will be better but its not the end of the world if you cannot and will be fine twisted an clamped. My only question is why the hell do you have so many ground cables of such a size. Ok one 150 amp for the starter motor current and then a few small cables for the rest of the electrical equipment. What are all the others ? We don't have that many on our 26 ton FLT s
never mind a little plastic car . OTT springs to mind .
40 years ago? I didn't realise electrics had been invented that long a go
Edited by peteslag, 08 September 2013 - 08:32 AM.
Posted 08 September 2013 - 09:15 AM
Take it you won't remember Selenium ark rectifiers40 years ago? I didn't realise electrics had been invented that long a goFFS , twist them together and clamp them, only been doing it for 40 fcuking years
