Who Much Warp In An Alloy Wheel Before Its Had It ?
wheels
4 replies to this topic
#1 kmidderigh
kmidderigh
  • 349 posts
Posted 09 September 2013 - 11:45 AM
Been having some problems with my shed recently - vibration at motorway speeds.
Done all the usual tracking,balancing, new tyres (backs had worn unevenly due to tracking issue) and even changed one of the alloys for a new one as apparently it had a big warp in it.
Thats helped alot and most of the vibration has now gone but not all of it.
So wanted to check if any of my other alloys were warped so borrowed an instrument for measuring the warp and of the remaining 3 original wheels the worst one is only warpred by 0.5 mm
My question is at 70mph+ will 0.5 mm warp in an alloy wheel cause vibrations ?
#2 TheRealVXed
TheRealVXed
    Sidekick
  • 5,975 posts
Posted 09 September 2013 - 12:00 PM
That should be balanced out by weights.
Have you had the TRE replaced as play in these will cause wobble even if the adjustments are correct.
#3 kmidderigh
kmidderigh
  • 349 posts
Posted 09 September 2013 - 06:57 PM
TRE - is that Tie Rod End ?
Edited by kmidderigh, 09 September 2013 - 07:02 PM.
#4 TheRealVXed
TheRealVXed
    Sidekick
  • 5,975 posts
Posted 10 September 2013 - 12:48 PM
Track rod end at the front, tie rod at the back :)
#5 Nev
Posted 11 September 2013 - 05:22 PM
I bent a wheel last year by about 3/4 inch, that was beyond balancing really, needed something like 120gramms to equalise it and it still wobbled.
Also tagged with one or more of these keywords: wheels
