Supercharger Rattling
any ideas
34 replies to this topic
#1 MartinS
MartinS
  • 5,173 posts
  • Interests:Track days
    Pubs
    Sausages
Posted 10 September 2013 - 05:43 PM
My supercharger makes a sort of cement mixer kind of noise at tickover. The noise isnt constant and doesnt seem to effect how the car runs. It was doing it when we went to Zandvoort but I only heard it occasionally and from inside the car, it sounded like the rear clam moving with that sound of vibrating fibreglass, and thought that, as the clam had only just been put back on. Its seems to have got worse now slightly.
I can only hear it on tickover but havnet got anyone to rev the car and listen out for it yet.
Below are links to two videos I made to capture the sound (sorry if there a bit big) and a photo.
http://s568.photobuc..._01/rattler.jpg
http://s568.photobuc...ATTLE2.mp4.html
http://s568.photobuc...062198266340361
Any suggestions or ideas will be very welcome.
Martin s
#2 CHILL Gone DUTCH
Posted 10 September 2013 - 06:02 PM
bearings gone or something in the charger catching the rotors
#3 vocky
Posted 10 September 2013 - 06:06 PM
you need to get the charger off and inspected, reasons as above
#4 Kieran McC
Kieran McC
  • 3,416 posts
Posted 10 September 2013 - 06:59 PM
Could be a bearing, BOT ££££££
#5 Kieran McC
Kieran McC
  • 3,416 posts
#6 fezzasus
Posted 10 September 2013 - 07:03 PM
Snout rebuild bearing kit is pretty cheap on ebay, with new oil and coupler - basically everything that can fail. All you need is a press to change it.
#7 Steve.i.am
Steve.i.am
  • 990 posts
  • Interests:Bends
Posted 10 September 2013 - 07:12 PM
Out of interest Martin, how many miles have you done on that charger and was it new when you installed it? Do any of the m62 peeps change the charger oil ever? Thought it was pretty much maintenance free?
#8 Bargi
Bargi
  • 4,483 posts
Posted 10 September 2013 - 07:34 PM
Most people and I think Lee and Joe change it when installing. Apparently oil is for lifetime but cant help to change it. Also they "should" have been shipped without fluids anyway.
#9 fezzasus
Posted 10 September 2013 - 07:49 PM
The oil is very unstressed as it doesn't get contaminated or exposed to combustion products, the heat cycles are fairly gradual and the oil itself is ashless so won't leave deposits. I changed mine as I changed the coupler, but don't see a reason to change it if you're not doing anything else.
#10 slindborg
Posted 10 September 2013 - 08:03 PM
Snapped bolts? Didnt that used to happen
#11 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 10 September 2013 - 09:08 PM
Not heard that before strange as above best get it off and inspect
#12 CocoPops
CocoPops
  • 17,182 posts
Posted 10 September 2013 - 09:20 PM
Or at least whip the throttle body off, see if it still makes same noise? Could be something caught around the butterfly?
#13 NickB787
NickB787
  • 7,813 posts
Posted 11 September 2013 - 04:32 AM
I had thought that but wouldn't the car hunt for an idle if there was an obstruction?
#14 MartinS
MartinS
  • 5,173 posts
    Pubs
    Sausages
Posted 11 September 2013 - 07:29 AM
Will take off the air filter end and have a look at the butterfly as that's the area it seems to be coming from but its really not clear exactly where. Sounds more like its coming from the odd shaped alloy thing that's external to the throttle body (yes, I am without question very technical!). SC was a refurbished one I believe and has done 27000 miles on the car. Martin S
Edited by MartinS, 11 September 2013 - 07:33 AM.
#15 Exmantaa
Posted 11 September 2013 - 07:33 AM
Is the noise gone with the belt off? The SC's internal coupler is then most likely the cause and easy to change. Check for excessive rotational play by turning the SC pulley by hand. (belt off)
#16 JohnTurbo
JohnTurbo
    SuperScruff
  • 3,635 posts
  • Interests:Performance cars!
Posted 11 September 2013 - 11:06 AM
Coupler is famous. Mine even came with one. Its a plastic doughnut with holes in, tenchically id imagine its designed to tolerate a very slight axial misalignment (angle) between nose and body csstings.
#17 fezzasus
Posted 11 September 2013 - 01:42 PM
#18 MartinS
MartinS
  • 5,173 posts
    Pubs
    Sausages
Posted 11 September 2013 - 02:53 PM
Sounds like it must be my coupler then as he described it perfectly. Whos got a coupler? Martin s
#19 Kieran McC
Kieran McC
  • 3,416 posts
Posted 11 September 2013 - 03:03 PM
Martin try Lee2.2 he has a lot of charger bits
#20 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 11 September 2013 - 03:58 PM
eBay sells them and I can do it no problem mate
Also tagged with one or more of these keywords: any ideas
